HEWLETT-PACKARD HP Mini-Notebook 210-1018CL Netbook Logo
teia Posted on Oct 18, 2012
Caps lock blinking on 210 hp mini, dark screen, fan on, f11 and f12 amber light on continuous
1 Related Answer
Anonymous
  • 39 Answers
  • Posted on Sep 28, 2011
SOURCE: sorry about my english... when i turn on my hp
1.Mo Bradley says do this:
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS
2.That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
3.Did this help you? If so Mo Bradley has one more quick tip to save your pocket.
I would like you to save on the high cost of replacement printer ink and I implore you not to buy Original Brand replacement ink. This is the rip off of the century and the Original Brand companies are not even ashamed. Try this website http://www.usainktank.com/ for ink which is mostly under $4.00 each (even HP ink) or if they don't have your printer model try some of the other suppliers of off brand printer ink. In the past I have used http://www.4inks.com/ and http://www.123inks.com/. They all have good quality off brand cartridges that will save you so much money.
The question on the hp g42 the f12 lightOrangestay's on And the cap key blinks 1 x every 3 sec.
could be faulty ram or screen faulty,or even over heating,clean out the fan.
I have an hp G42 notebook when i hit the power button i hear it turn on but nothing happens only the caps lock key light begins to blink
hp blink error code:
caps lock blink once: cpu error
caps lock blink twice: bios problem
etc,,,,
please, what is the numer of the blink ?
I hit f12 on my hp mini 210-1170nr. now my wireless is disabled. how to fix
If pressing it again doesn't do anything, rebooting might reset it. You may even be able to change it in the BIOS.
1helpful
My HP Mini 210 1081NR Won't Turn On?
you have a motherboard problem.
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
6helpful
2answers
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
14helpful
3answers
I need to restore my HP mini 210 to factory settings
try pressing f11 on boot up to see if you have a recovery manager insalled
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
