Question about HP DeskJet 712c InkJet Printer
Hi, I have an older HP 712C printer. The cartridge light is blinking and I've forgotten how to determine which cartridge is empty, the color or B&W? Thanks! Rich
    Genius:
  • 2,120 Answers
If there are blank lines cutting through the letters, it's probably BLACK.
Posted on Jan 01, 2009
My HP DeskJet 712c InkJet Printer's "ink light" won't stop blinking!! I have tried changing ink cardridges, checking for paper jams, unplugging and replugging cords and re-starting computer. None...
Hello.
Give this a try:
1. Power off your printer
2. Remove and reinsert the cartridges. You should hear a "click" when properly seated.
3. Power on printer.
4. If light is out, print a test page for realignment.
Note: Be certain that the tab is removed from the cartridges and you are using "genuine" HP cartridges.
Hope this helps.
Oct 31, 2010 | HP DeskJet 712c InkJet Printer
There is an orangy/yellow teardrop shaped light blinking on/off on my HP Deskjet 5740. I brought the ink cartridges into Office Max and they confirmed they're not empty. Put them both back in and the...
Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first.
Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01082964&lc=en&dlc=&cc=us&product=305961
Oct 04, 2010 | HP Deskjet 5740 InkJet Printer
My hp 712c printer prints only the pink band when I run a color test. I have replaced the original cartridge. Any ideas about the cause and solution.
The cause is either:
* clogged ink-jets not allowing yellow & blue ink to move from the ink-cartridge onto the paper;
* busted electronics inside the printer, causing the ink-jets to not "spray" at all.
Use the software to try a "print-head-cleaning" cycle.
If that fails to improve things, it's time to replace the printer.
Jun 24, 2010 | HP DeskJet 712c InkJet Printer
HP Deskjet 712c Printer will not print in black & white
you need to check the head of the printer, im sure is bad, it depends how old is the printer but the head on the printer goes bad if printer has not been used for long time or if you left the old empty cartridge seating inside for a lont time, you can do a head check on the settings of the printer and also do an alignment thank you
Jun 16, 2009 | HP 5069-4515 Keyboard
Can't get rid of blinking cartridge light on hp deskjet 712c
maybe they need replaced..if already done..then run a calibration and clean cycle from print manager panel
Oct 13, 2008 | HP DeskJet 712c InkJet Printer
Black light & print cartridge light is blinking. I changed the black cartridge but did not change the color cartridge cause I never use color. Both are in the printer. Black Light is blinking and...
Unfortuantely , to solve the issue , sadly, yes you will have to replace the empty cartridge to continue to use the printer in a normal fashion. Its a sneaky and dirty trick many printer manufactuers do to make more money off of the customer through the purchase of printer ink.
Aug 25, 2008 | HP Computers & Internet
Blinking lite on a hp deskjet 970cxi printer
2 reasons.
1)paper jam internally. chk carefully.
2)paper sensor problem.
just moove a paper in tray &tell me green lite is glow/not?
Aug 11, 2008 | HP Office Equipment & Supplies
Hp lazerjet 2550n
Your Black cartridge is empty.
From the user guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
Here is a link for the User Guide:
2550n User Guide
If this solution has been helpful, please take a moment to rate it. Thanks!
Jun 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
HP DeskJet 712c InkJet Printer Logo
163 people viewed this question
Seeker5211
Seeker5211
