2004 Ford Escape Logo
Barry Posted on Oct 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The escape starts&goes down the block and hesetates when u step on the gas big tim
The escape hesitstes big tim when u step on the gas petal and will make it down the block and then end up pushing it back to the drive way!! what can cause the escape to do this, fuel pump, or fuel pump and or different thing or is it many things!!!
Stephen
Level 3:
Top Expert:
  • Ford Master 21,873 Answers
  • Posted on Oct 18, 2012
 Stephen
Ford Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6199792
Points
67230
I would start by checking the fuel pressure at the injectors with a gauge.
If you have not yet replaced the fuel filter you might want to do that first.
4 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Apr 21, 2009
SOURCE: Front end vibration when accelerating above 45
Have the CV joints checked for excessive play, that is the most common cause of this type of vibration on acceleration.
Anonymous
  • 290 Answers
  • Posted on Sep 01, 2009
SOURCE: 2003 Ford Escape won't keep running
2 solutions: first, ignition control module is getting hot and shutting car down. 2nd; you didn't mention your dash(service soon) lights were on.<p>
You said the fuel filter was pretty clogged up. It's sounds like a bad case of EGS(ethanol gas syndrome). The ethanol;being a corn deritive;acts like corn liquor(which is what is is), and turns the fuel to goop, and adds large amounts of water through out all the systems.<p>
It clogs up the fuel lines,the injectors, and ruins fuel pumps. It also puts heavy carbon on egr valves, int. and exh. valves, and can ruin oxy sensors, and catalytic converters.<p>
Let's try the cheapest way first:Buy a can of SEAFOAM and Berkline 2+2 at your parts store. Take out the oxy sensor(s) and clean the ends using the 2+2 and re-install.
Then change out the fuel filter again. Pour the SF into a tank of PREMIUM(only) gas. Change the pcv valve. Then start vehicle and let idle for 3-5 min(even if you have to rev it up to do it to get the SF flowing through the system), and then drive it 10 hard miles.<p>
Replace that fuel filter, and then let it idle some more. Your car sounds like it is really messed up bad. Unless you take it to a garage that has a fuel system cleaner machine, this is the best way to do it.<p>
After this, add SF every 3-5000 miles to your tank. It will prevent this from happening again. Also; to be on the safe side. Have a PSI check on your fuel pump. This goop could have burnt it up. I hope this helps.
Anonymous
  • Posted on Sep 06, 2009
SOURCE: 97 expedition, motor shakes and stalls
Check all vaccum hoses for leaks
Anonymous
  • 122 Answers
  • Posted on Oct 27, 2009
SOURCE: Loss Of Power & Unable to Crank Beyond 2-3 Seconds...
You have an issue with your throttle actuator, try cleaning in the area with carb cleaner but more than likely the actuator will have to be replaced
2answers
If i step on the gas hard it starts to hesetate and gerk, but if i do it slightly its fine
WHEN YOU STEP HARD, A STRONG GAS INJECTION HAPPENS.
MAYBE IT IS TEACHING YOU TO SLOW DOWN.
Trottle control/powertrain
Sounds like a cylinder misfire under load from an arcing coil boot. recommend replace all coil booties ( and spark plugs if over 60k old).
Gas petal goes down to easy.
You will need to replace the pedal assembly to repair this.
2answers
93 corvette spins over has fuel pressure but no fire what is the comman problem
check timming check for spark at distr if all esle check dist cap then
1987 Plymoth Horizon wants to stall out
sounds like its starving for fuel, bad gas in the tank, clogged fuel filter. that's where i would start. good luck
1993 honda civic
Try checking the snorkel tube between the air cleaner and the intake. Open the hood, and have a friend try to rev the engine, and watch the tube...my '92's was collapsing and starving the engine, couldn't get more than 3500-4000 rpm. Could also be a fuel pump problem like low pressure or bad line.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
