Question about Kitchen Ranges
Oven overheats when baking - Kitchen Ranges
    Genius:
  • 2,920 Answers
I would say you need to call a repair man but u havent said if its gas or electric if its electric id say your heating element is being over worked or worn out.if its gas it would have to do with the thermocoupler.call a repairman it shouldnt cost alot
Posted on Jan 01, 2009
    President:
  • 948 Answers
Your themostat may be bad. Put an oven thermometer in your oven and set to 250 degrees. If the oven temp raises beyond 275 your thermostat is not working properly and should be replaced. If you know the oven make and model someone may be able to provide assistance, otherwise that is a job for a professional since an improperly working unit can cause a fire.
Be careful.
  • Kitchen Ranges Master
  • 13,433 Answers
Lower the heat, if the oven over heats on any setting, your controls are probably kaput and would require to be replaced.
you didn't provide much detail in your questions.
appliance parts are available at
http://www.repairclinic.com/smartsearch.aspx
    Novelist:
  • 163 Answers
Please give the detail about the model number?
Reheat baked ziti
Reheat baked Ziti in a microwave. Heat it in 20 second intervals until it is hot enough. Do not overheat it and enjoy!
Jun 05, 2017 | Microwave Ovens
Bosch oven is fan always on when oven is in use? Can it be turned off?
If it is a fan forced oven the fan has to be on all the time or the element will overheat and destroy itself if it is a multifunction oven it should not be on when in the classic bake setting
May 29, 2011 | Ovens
THE OVEN WONT STAY HOT WHILE BAKING IT CUTS OFF?
This is a frequent problem with thermostats. The thermostat is an electric switch which from overheat and long time use they malfunction and you need to replace it.
Nov 25, 2010 | Ovens
OVEN WILL NOT HEAT UP AFTER WE USED THE SELF CLEANING OPTION
Most ovens have a thermal fuse on the back. This is a safety device which kills the power to the bake/broil elements if the oven overheats. Self-clean has been known to trip these devices in which case it needs to be replaced. Not a user-serviceable part, but not difficult to replace either.
Jun 26, 2010 | Whirlpool Ovens
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
The oven seems to overheat because it burns everything you try to bake
thermastate controler has gone and you have no tempreture control,you will need to seek out a good electric man,cost off thermistate should be approx 60-70 dollars
Nov 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Pepper Oven overheats
This problem is caused by a faulty thermostat controller. This is the dial that you use to set the temperature for heating.
Jun 17, 2008 | Fisher and Paykel Ovens
Whirlpool Wall Oven sometimes power fails in middle of a baking session. Display goes blank and oven will not work for 10-20 minutes. Then oven will come back on with a PF readout.
Could be several things; 1. Electrical connections in oven are loose. 2.The circuit breaker for the oven could be failing. 3. The electronic control is failing. Make sure when oven is operating, the cooling fan is operating. If the cooling fan is not working, the electronic control will overheat and shut down.
Jun 01, 2008 | Whirlpool Kitchen Ranges
Kitchen Ranges Logo
15 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
