Question about Miele CVA4070 Coffee Maker
My meile does not make good coffe
My Meile's coffee does not turn out as good as all my friends meile builtin coffee machines. We all have the same machine, but mine does not even produce crema like the others. we have tried all different coffee beans and still have not figured it out.
  • louiev2002 Jan 01, 2009
    same thing.... first cup is good, strong.. just right. subsequent cups are weak... descaling, cleaning,etc don't fix the problem
    Problem Solver:
  • 10 Answers
Remove the Brew Unit from the maschine and clean it very well und running water. Thn go into the Main menu and switch back all settings to factory defaults. Then take a vaccum cleaner and put the pipe in the small hole where the coffe falls into the brew unit (knock a bit on the maschin inside). Put out the bean container and do the same with the hole where the beans go into the grinder. Then put everything back in and start a cleaning process for the brew unit (do it 2 times).
After that your Problems must be gone. The Problem is between the grinder and the brew unit. the grinded coffee has bee stuck and is not falling into the brew unit .... that happens when you use beans with lots of oil inside  .... or coated beans .... they "glue" the chute .....
Mr. cool
Posted on Feb 01, 2009
My meile machine is stuck in the descaling mode
When you start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
May 23, 2014 | Miele CVA4070 Coffee Maker
Meile coffee machine locked in descale
once it is time to descale, you must complete. there is no way to bypass.
May 25, 2012 | Miele CVA2660 Stainless Steel Coffee Maker
Meile cva 4085 not brewing no error
Hi. i need more info. does it turn on, does it heat, make steam, make any noises?
Sep 24, 2011 | Miele Coffee System
My miele cva 4075 is not heating the frothed milk or coffee up as well any more...sometimes a Fault 73 shows on the screen..i have cleaned the brew unit with tablets and water etc...what should i do next?
Hello Loriktarrant,
I understand the your Meile CVA4075 is showing you an F73 code. This code means that the brew unit needs to be cleaned. Here is a link to the owners manual on page 40 it shows you how to manually remove and clean the brew unit. The other issue you are having with the milk and coffe not being hot enough could be to the machine needing descaled.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man enter the numbers in the box and click download.
Thank you for choosing FixYa.com
Justin
Mar 12, 2011 | Miele Coffee System
I have a Meile CVA 615 coffee maker that has a problem. It is producing lots of liquid in the collection tray on the front of the machine. It is also taking longer to make a cup of coffee and...
Hi
It's time to de-scale your machine, please check the bellow link to read the manual and check how to de-scale your appliance:-
https://www.ajmadison.com/ajmadison/itemdocs/CVA615_us.pdf
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 17, 2011 | Miele Coffee System
My meile coffee machine cva620 is not froffing properly
check to see if your steam nozzle is clear unscrew tip and clean also run descaler thru to make sure steam tank is clear if still not ok steam tank thermostat may be faulty need to service machine hope this helps
Nov 05, 2009 | Coffee Makers & Espresso Machines
Meile Coffe System Descaling
The big tablets are for descaling, and go in the water jug, the small ones for cleaning the brew unit, and pop in the top. The boxes that they come in should tell you what they are - in many languages!
Do you have the instruction book?
May 10, 2008 | Miele CVA4070 Coffee Maker
Meile espresso maker does not expel air
Press Hot Water and Steam Button at same time.
Dec 24, 2006 | Miele CVA615 Espresso Machine
Miele CVA4070 Coffee Maker Logo
550 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
