Lexmark Pro 715 All-in-One Printer Logo
Patricia Posted on Oct 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to copy
How do I turn on screen with choice to copy or scan
  • Official Brand Answer 3,344 Answers
  • Posted on Oct 26, 2012
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923730
Points
5508
Just press the Home button and it should show you the options to Copy or Scan. Just use the up and down buttons to scroll the menu.
1helpful
I have HP LaserJet Enterprise 700 color MFP M775dn ptinter and i forgot the username and password to access the setting through the web, any way to reset it please ?
You will need to perform a partial clean. Turn off the printer. Turn it on and watch to boot up on screen closely. When the black line appears under the HP logo, touch the HP logo. Display will go to a black and blue display. Use the arrows on screen to scroll down to administration, select partial clean and press ok, and then press back arrow until continue appears on screen. Press ok and unit will restart. You will lose most of your settings this way but you have no other choice.
3answers
How to remove blackscreen wallpaper from window xp
It could be virus. Try running a full system scan.
Scanner won't send a copy to computer
Good choice going to a Mac. Open Scan Icon in Applications and go from there. It's easy. Always refer to the manual with new stuff.
I have a HP Photosmart 2575 xi all in one printer and I need to be able to scan documents and photos. I have no idea how to do it. How do you scan these things. I use the printer and the copier but have...
1. Turn on your computer, wait for it to boot up, then turn on the printer.
2 Double click the "HP Photo Imaging Director" icon on your desktop ( placed there when your
printer was installed on your computer ). A menu screen will appear showing the scanning
options of the printer.
3 Place your document or photo on the printer's glass top and close the lid.
4 From the menu screen, click on " Scan Picture " or " Scan Document "
When "Scan Document" is selected, a secondary screen will appear from which you will have to
make choices. After making your decisions, click "Scan" from the listed screen.
When "Scan Picture" is selected, one scanning pass will be performed, another pass will be
made after you view the result of the first pass.
Scanned pictures will go to the HP Photo Gallery and your "My Picture" folder.
Scanned documents will go to your "My Documents" folder.
Good Luck with your scanning operations!!
1helpful
The little screen on the printer which gives you the choice of print, copy or scan has stopped working. It is still illuminated but with no writing, please advise?
You may need a shop, there's a new cable assembly for that that Canon shops can get. The flat cable to the display goes bad and needs replacement.
Minolta Dialta Di 350f how do you change the display language
1. User's Choice Function Setting Procedure
<Procedure>
1. Press the Utility key.
2. Touch the “User’s Choice” key.
3. Select the appropriate screen from the menu.
4. Select the appropriate function.
5. After the settings are complete, touch the “Enter” key to validate the settings.
2. User's Choice Function Tree
Memory Recall
User’s Choice 1/6 Mixed Original Detection
Language Selected **************** SEE THIS ONE
Original Copy Default
Auto Paper/Auto Size
User’s Choice 2/6 Drawer Priority
Special Paper
Multiple-in-1 and Booklet Copy
Zoom
Auto Panel Reset
Energy Save Mode
User’s Choice Mode User’s Choice 3/6 Plug-In Counter,ID Key Reset
Auto Power Off
LCD Back-light Off
4in1 Copy Order
Density Priority
User’s Choice 4/6 Default Copy Output Levels
Priority Density
Output Priority
Intelligent Sorting
Output Tray
User’s Choice 5/6 “Small” Originals
Scanner Dry
User’s Choice 6/6 Density (ADF only)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2helpful
Konica Minolta bizhub 750 scan file type default settings PDF
Once you have selected PDF on the screen touch you Ulitly/Counter button, then select User settings, display settings, Scan Basic default.
can go to konicaminolta us web site and down load a operators manual for scan, copy, fax etc.
Scanning of negatives and slides to a computer -Is it possible
Please follow the instructions below to use the Scan and Save option in Smart Panel
1. Open Smart Panel and double-click Scan and Save
2. The scanner normally defaults to AUTOMATIC MODE and will scan without any intervention. Should you wish to use PROFESSIONAL MODE or HOME MODE, simply click on PAUSE and the MODE you wish to use.
3. After the scan completes, you will be taken to the VIEW IMAGES screen. Should you wish to change the file name, click on IMAGEXXXX( X representing the number) and enter the file name of your choice. Click NEXT
4. In the SAVE FILE screen, select your FILE PATH and FILE TYPE. After making the adjustments you wish, click on SAVE.
6helpful
4answers
Hp psc 1100/1200 all-in-one does not scan with vista..
I had the same problem. Click Start, Windows Photo Gallery, from that screen, you can select import from scanner. The 1200 series printer should be a choice to select. You are then able to preview the image or document, then press scan. I found this out through the HP support website.
2answers
When I turn on the printer "Download Mode" appears on the lcd screen.
The machine might be trying to download the latest firmware wait a few minutes it may go if not it is it the user manual under on screen messages.
Thanks J
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
