Question about Philips 51PP9303H Rear Projection Television
Philips rear proj tv multipoint help
Hi is there anyway you could help me figure out what i need to fix my multipoint. Guess i need to buy some things and replace. What do i need to give to you for you to tell me what i need to get. thank you...
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and shophilips rear proj tv multipoint help - 2c07611.pngaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
Posted on Feb 13, 2009
I have a Phillips rear proj. 60pp9202/17f with a color problem
3_24_2012_6_00_06_am.jpg This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link
Jul 12, 2009 | Philips 60P8341 60" Rear Projection...
My phillips 60 in projection tv has color distortion and the multipoint converge wont let me adjust the cross hairs
Hi..... well if is a LCD Rear projection Tv is a issue with one of the color filters, and you will need to change at least the optical block or the light engine system, I always buy them from
If TV is DLP it might be a issue with the color wheel, you might be able to hear a buzzing sound.
Jun 27, 2009 | Philips 60PW9363 60" Rear Projection...
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking.  Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site They are working on a complete kit for this model.
Nov 12, 2008 | Philips 60PP9202 60" Rear Projection...
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
Philips Model: 46pp93 02/17F Multipoint coverge Repair.
I really would love to tell you that you can do this on your own, but I would really suggest taking it to a professional and having it fixed. If you don't know what you're doing you could just cause more damage.
However, if you want all the available manuals for this television you can go here:
register for free and access their library of manuals.
May 25, 2008 | Philips 43PP9202 43" Rear Projection...
To much green
Jan 14, 2008 | Philips 60PP9202 60" Rear Projection...
Magnavox 6p5441c103 rear
You can get it a stores online like,,, or any electronic shop. It is called CRT Coolant, you will need about 3 or 4 bottles. It is really important to not waste on board, because this may short out set.
Dec 21, 2007 | Philips Magnavox 51MP392H Rear Projection...
C Color is way outta wack on my 56 inch pilips rear proj tv. HELP
Oct 28, 2007 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
