Question about Microsoft Windows XP Home Edition
Wrong default storage hard drive?
Everything created on HP Pavillion/Windows XP Home(2002), and everything downloaded to it, is being stored on the D Drive instead of the C Drive. Is there a simple way to change default storage back to the C Drive as it should be? (C Drive has 69% free space, while D Drive is filled up, and you have to delete something to store anything new.)
  • myoung6264 Jan 02, 2009
    Clarification requested by tigerjim48: I am new to computer use, so (blush) I don't know what a "download manager" is...
    But the files stored on D include Word Perfect documents, music downloaded from a flash drive, and screensavers downloaded from a Web site, if that helps... myoung6264
  • Jim Kirk May 11, 2010
    What download manager software are you using and what other programs are storing files on the wrong drive--Word, Excel, etc.?
  • 36 Answers
Here are some suggestions; if they don't do it, just let me know and we'll try something else!
1. When you download anything from the Internet, it will usually give you the option of "Save" or "Run"; when you choose "Save" you should have the chance to specify where it will be saved to. Specify "C:\My Documents;" "My Documents" pops up all over the place, so it should be easy to find; a lot of programs (including download managers) will often default to it. (Default means it will happen if you don't do anything to change it.)
2. Go to Start>Programs>Accessories>Windows Explorer. When that comes up it will show you your drives and folders on the left hand side, and more folders and files on the right hand side. If you click on C: on the left hand side, it will show you all of the folders on C: below it and on the right hand side. Click your cursor on C: so that it is highlighted, move your mouse up to the File Menu, press File, and press New Folder. Name it "M's documents," "M's stuff," etc. Once that is done, you can save everything to there.
3. There is not room here to walk you through it, but go to Help and type in copy. Once you understand that, you can go back to Windows Explorer, copy the documents off of D: to C:\M's Stuff. Remember, you're just making a copy here. Once you have it all copied over, then you can go back and delete them from D:, but I wouldn't do that for a while, until you're sure you have everything you want or need on C:
4. WordPerfect has in it a place to specify where to save documents to. Go to Help in WordPerfect and type in location, files, or file locations. That will let you specify that all documents are saved to C:\M's Stuff.
5. If you need more help, just ask another question and I'll see if I can answer it for you.
P. S. It's not as hard as it might first appear!
Posted on Jan 02, 2009
    President:
  • 2,692 Answers
File SAVE AS "C"                              not file SAVE I always save all of my files on a different drive from the OS.
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
I installed windows XP professional version 2002 but it doesn't have sound and I cann't get internet,my pc HP s3220n before hard drive damaged it was windows Vista,please help !!!
You have to install the drivers into your computer. You can get the drivers for Windows XP in the website of your computer's manufacturer. Since you cannot connect to the internet using that computer, then you can use a different computer. Download the drivers and save them into a USB storage device. After downloading all drivers, install them in your computer.
If you want to make sure that all drivers perform well, then I suggest that you keep them updated. You can use RadarSync if you don't want to do all updating manually.
David
Apr 15, 2013 | HP Pavilion Computers & Internet
Where do I get the proper drivers for my new hard drive?
Go to HP.com and look under support/downloads. You should be able to get everything that you need there.
Apr 15, 2012 | Computers & Internet
Its telling me the hard disc is corrupt and is reloading it but it doesn't fix it and takes ages but is the same
Your hard drive has a problem and needs to be formatted. this has happened to me twice already but not with the original hard drive that came with the ps3, I changed mine to a 500 gig drive which had the problems.
the bad news is that you have lost everything that you saved onto the drive and need to reformat and reinstall the ps3 operating system.
If you go through the system settings there is an option to format the drive. Do that.
Then you need to get a USB flash drive, and follow the steps below
Download the update and save the file to a compatible storage device such as Memory Stick, Memory Stick Duo, a USB or PSP.
Before starting, use your PC to create a folder named "PS3" in the storage media or USB. In this folder, create a folder named "UPDATE" (the folder name is case sensitive and must appear in capital letters). Once the UPDATE folder is created, download and store the update for PS3 system software.
Once the update saved, remove the storage media and connect to your PS3 via the slots under the slot cover, or USB, depending on the storage medium used.
Once the storage media connected, go to Settings on the home menu of the PS3, select System Update, then update via Storage Media. Select the storage media connected to the PS3 installs the update data stored there.
Good luck.
Dec 06, 2010 | Sony Playstation 3 (PS3) Console
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
MY HP PAVILLION DV 1000 HAS NO SOUND DEVICE NOW
Below is a link to download the sound drivers for your laptop. Download, install and reboot and everything shoud be fine.
ftp://ftp.hp.com/pub/softpaq/sp28001-28500/sp28481.exe
Jan 22, 2010 | HP Pavilion dv1000 Notebook
Good Afternoon, I have an 64bit HP Pavillion System, brand new, with Vista Home Edition, I previously purchased a 1TB USB external HD Simpletech, works fine with XP, but not with vista, keeps looking for a...
there have been alot of problems in the past with vista not all external components are compatible with this program.i had the same problem with vista so i got rid of vista and started using windows xp home edition since then i have never had a problem with it not recognising any device i have added to my computer.i hope this helps.
May 06, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
Blue screen
If  you are trying to install Windows XP in latest Notebook, it will not be able to detect the Hard Drive since all the latest Notebooks are shipped with SATA Hard Drives and by default and Windows XP will not be able to detect SATA Hard Drives by default.
If you are having a Intel based Notebook, you need to download the SATA Drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36132.exe
Find the instructions to create a bootable XP Disk using the SATA Drivers from the link below :
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Hope this helps...
Mar 07, 2009 | HP Pavilion dv6000z Notebook
Hp Pavillion restore problems
It Could be a bad stick of RAM I have seen a bad stick cause all kinds of problems.
Try booting with another stick of ram and see what happens.
Good Luck
wwiz
Oct 26, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
