Question about Gateway Computers & Internet
Gateway Laptop overheated and stopped working.
My son has a Gateway model # MT3422. He said that the fan stopped working and then the unit overheated and now it will not power-up. Is this the mother-board, CPU, or what? Thanks in advance for your assistance.
  • Gateway Master
  • 32,281 Answers
Usually when the laptop overheats the CPU shuts down, and after it cools down you may be able to power it up again, unless the CPU has failed.
If you are able to get the laptop working, get the fan replaced, if it laptop doesn't boot up then there is a serious problem (most likely a costly one).
Posted on Jan 02, 2009
Is my laptop overheating? It will work for a bit then get a black screen w/ lines through it.
Hello Kenny,
You laptop likely is not overheating per se, but it appears that the cable located between the video card part of the motherboard and the monitor may not be secured as it should. Vibration, and perhaps temperature, can cause this cable to shift ever so slightly causing symptoms that you describe.
If taken to a repair shop, the charge should be nominal for them to disassemble the laptop to the point where they can access and secure the cable. At worst, the cable may need to be replaced due to wear.
The easiest way to confirm that it is a cable or not is to try and plug in a monitor to the back of your laptop. If the problem appears on the panel, and not the external monitor, then you are almost certainly looking at a cable issue. If the problem appears on both monitors, then it is a different issue, perhaps overheating like you suggested.
Aug 17, 2010 | Gateway MT3422 RTL Notebook
GATEWAY mt3422 WILL NOT BOOT UP. Power light is
if your harddisk is ok than , u open your notebook motherboard and clean processor fan properly,,than again fitting your laptop than boot from cd rom (make sure that your cd rom is ok )
Apr 14, 2010 | Gateway MT3422 RTL Notebook
Cooler Problem ?
There are devices you can purchase which aids in pulling more air through the system and keeping it cooler. One which I purchased and am quite pleased with is by Antec. It is a dual fan unit that is powered by one of your USB ports. You place your laptop on top of the unit, power it on, and it works wonders at keeping your system free from damaging heat buildup and those annoying shutdowns!
There are other units made by other manufacturers available as well. Some more expensive, some less. I have always had good luck with products from Antec and their price was reasonable as well.
Jan 24, 2010 | Gateway MT3422 RTL Notebook
Gateway MT 3422 problem
There has been a lot of problems/ complaints about this particular product. That is why I always recommend HP notebooks.
You can take it to a service centre where they deal in Gateway products but I bet you might need to replace your motherboard.
Good luck.
May 21, 2009 | Gateway MT3705 Notebook
Gateway boot problem
This mostly happens when your motherboard is bad or one of the memory modules is bad.
The led light comming on indicates your power pack is ok but a component is failing to start especially when the laptop stops at the first screen stage where the manufacturer names appears.
The steps needed to solve this kind of problem would require technical skills and physical inspection.
If you still have a waranty period then seek a free service repair from an authorized or certified gateway service centre at the nearest centre closest to you.
If your warranty has expired, i still advise taking your Laptop to the closest Gateway service centre.
Wireless button
To turn on your wireless on your keyboard hit fn and f2 at the same time
Dec 21, 2008 | Gateway MT3422 RTL Notebook
Computers & Internet Logo
908 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
