Question about Jenn-Air JCD2295HES Side by Side Refrigerator
Fridge keeps freezing
My Jenn-Air refrigerator section keeps freezing. I've had a tech out twice, and they can't fix it. They replaced the Elec Motor Kit, worked for about 6 months, then broke again. This time the Water tank inside fridge froze and broke, so they want to replace it without fixing problem of freezing. I told them no since they couldn't tell me how to fix original problem. Do you think it's a thermostat?
    President:
  • 1,214 Answers
Chances are, they replaced the wrong parts, or didn't replace all the parts, assuming they replaced an electric motor kit. I would need to know the P/N of the electric motor kit to confirm what was replaced.
Based on the fact that it froze the drinking water tank, and if they replaced the electric motor kit, the problem is more likely the temperature sensor or the control board.
Let me know what the P/N is of what they replaced and we can be more precise.
Posted on Jan 14, 2009
Jenn air refrigerator jcd2389ges freezes fridge
Bea, try this. UNPLUG the refrigerator for 12 hours and keep the fridge and freezer doors open. You might lose some food. NOW you will find some water under the fridge. clean that and now power up the fridge. Make sure you hear the motor working. Your fridge will start cooling. Keep at recommended temp.
Mar 07, 2014 | Jenn-Air JCD2389G Side by Side...
Refrigerator side freezing
you could have a bad damper,this is located in the fridge section,all it is is a door that opens and closes to let cold air into fridge,sounds like yours is stuck open.remove the bottom kick panel and look for the tech sheet,it will tell you how to put it into diagnostics,the board will open and close,if it doesn't you know it's bad.go here and look at part number 13
http://www.searspartsdirect.com/partsdirect/part-model/JENN-AIR-Parts/Refrigerator-Parts/Model-JBR2086HES/1266/0161000/M0610191/00008?blt=06&prst=&shdMod=
Jul 12, 2012 | Jenn-Air JBR2086HES Stainless Steel Bottom...
Ice build up in freezer
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
This will help to solve the problem....
Aug 18, 2011 | Jenn-Air JCD2389G Side by Side...
I have a Kenmore Trio 76504 that the refrigerator keeps freezing products on the back of any shelf or crisper bin
Good luck in solving the problem....
May 15, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
My fridgedaire side by side freezer's condensor is freezing over and warming the fridge side, I defrosted it the fridge side is keep cool enough to keep food but the freezer side will not get cold to...
Hello, This is a type of faulty you can handle yourself, most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
I hope this will help in solving the fault.....
May 12, 2011 | Refrigerators
My Maytag refrigerator (MBF2556HEW) keeps freezing over in the freezer section and choking out the refrigerator. I have unplugged it and allowed it to completely defrost and within several days, freezes...
You can fix the problem yourself, all you have to do is to follow the procedure that is below,
Take care in solving the problem.....
May 10, 2011 | Maytag MBF2556HEW / MBF2556HEB /...
Hi, I have a jenn Air side by side fridge, and it keeps freezing everything. How can it be fixed?
your cooling temp is too low i take it you have decreased the thermis in this case the thermis is not working and will need replacing
best of luck
please remember to rank my reply
Dec 01, 2010 | Jenn-Air JCD2389G Side by Side...
Water filter inside fresh food compartment keeps freezing up? Frigidaire brand 3-4 years old. Thanks, Steve.
hello,
Check the cold control, and also the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout....
Aug 08, 2010 | Frigidaire FRS6R5EMB Side by Side...
Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
236 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
