Problem Installing batteries in cordless headphones
I received a ARKON HP1180 cordless sterea headphone system as a present.I assume the batteries need installing as they were supplied loose with the system, but I cannot find where to install them. The instructions say to insert 2 LR03@AAA batteries on the RIGHT HAND receiver headphone, and afterwards to close the battery compartment cover. THERE IS NO COVER.The REPLACING batteries instruction tell me to remove the cloth padding around the left and right headphones and install the batteries in their housings as ilustrated. Ther is no illustration and no housing. CAN ANYONE HELP?
Having removed the soft pad, there is a flat sheet of plastic attatched that goes round the speaker (sort of doughnut shaped, with a hole in the middle where the speaker sticks out). Carefully pull this perpendicular to the speaker, and it'll come off (the four rectangles you can see on the surface of the sheet are pegs that click into the main body to hold it in place). Under there will be one battery compartment. Repeat both sides, and you're done. This stumped me for ages!
Posted on Feb 02, 2009
Looking for headphone
that's a bit challenging. especially in singapore
Mar 28, 2014 | Arkon Ar-800tx Infrared Wireless...
How do i connect headphones to htr-5960
Does it have a headphone jack on the front of the (Reciever)
Dec 05, 2012 | Yamaha HTR-5960 Receiver
Sennheiser hdr 160 will not pick up the signal from the receiver
assuming the battery is charged, have you tried to switch to a different frequency band, etc.?
check page 28 of the user manual for possible actions when there is no sound in the headphone.
Oct 12, 2011 | Sennheiser HDR 160 Wireless Headphones
Right headphone will not play music
sounds like a broken wire. have them exchanged.
Mar 22, 2010 | Bose in-ear headphones - Black with...
Wireless headphone hook up
Hello depends on how you hook it up as thee are several ways.
many receivers will output sound through the headphone jacks even when the speakers are left on.(my receivers require that you manually turn speaker A off when using headphones)
it may be possible for you to connect the headphones to a tape output but this will require headphones that have a volume control on them or an external.volume control knob.. You may encounter a problem as I am not sure if a tape output will provide enough signal to drive a pair of headphones. this would not be a problem if you use a pair of WIRELESS headphones as they have their own power source onboard..
A set of wireless headphones could also easily be connected to the output on the back of the TV but assuming you have your receiver plugged in to the TV audio out you may need a couple of Y adapter cables.
Also if your receiver has a pair of PRE OUT jacks those would work to power a set of wireless headphones may also power a wired set but once again not sure on power as I have never needed to try it.
Hope that helps a bit
Jan 09, 2010 | Audio Players & Recorders
I have Arkon HP1180 corless head phones. Does
To replace the batteries, remove the cloth padding from around both ear peices. You them expose a plastic lid with a slot in it. In the front of the plastic are four small inserts this holds the battery cover in place. Get a thin screw driver and slide it down the back of the cover and gently prize it off, not much force required.Replace battery on both sides. To put the cloth cover back on put one end of the cover in the slot and keep turning it until the cover is all the way on,do this before you press the front plastic cover back on. Have fun
Apr 02, 2009 | Unwired Audio Players & Recorders
I have an Arkon HP1180 Cordless Headphones with no instructions.
hello know the green light stays on only goes of when you take head phones of unit
Mar 22, 2009 | Unwired Audio Players & Recorders
RS 130 not working?
I am having the same problem...i tried resetting it as well...no luck
Jan 13, 2008 | Sennheiser RS130 Headset
142 people viewed this question
 Grubhead
Grubhead
