Question about ASUS P5GD1-VM Motherboard
Pc not starting up
As i see a bit further down , somebody seems to have the same issue.
Now what i see: when pressing the start button , the fans come on , but die after a couple of seconds.
I tried starting without drives or hard disk attached , but the problem stays the same.
Now what i wonder is: my power supply is 400 watts.
Is this adequate for starting the mobo with the 3 gig processor , or must i go higher?
Happy new year to all of you out there!
Robert
  • fa372066 Jan 02, 2009
    A very big thank you to everybody who tried to help me here.
    While clearing the bios , i was called away for a brief moment .
    I forgot to replace the jumper , that was still on the table.
    I tried to switch on , but no more life.
    Looking at the manal , it seems i took away the commands to make it work , so it looks like vertical filing , and learn from my mistakes.
    Thank you all for trying.
    President:
  • 948 Answers
"Now what i wonder is: my power supply is 400 watts.
Is this adequate for starting the mobo with the 3 gig processor , or must i go higher?"
400w should work, although if you add an additional video card and multiple drives to that you're getting close.
Try removing all but one memory module, blowing any dust from the motherboard, and double checking the fan is secured properly to the processor. If you are using a separate video card, remove and reseat that too.
Posted on Jan 01, 2009
    Scholar:
  • 35 Answers
You should reset your BIOS and see if this solves the problem.  Consult your motherboard manual or visit www.asus.com and download the manual for your specific motherboard for instructions on how to reset your CMOS (BIOS).
If this does not help, please give me your specific motherboard model #, type of RAM being used, how much RAM, and how many sticks.  Also, when did this problem first occur?  Was the pc functioning properly at first, or have you installed a new motherboard?
  • Tim Hallman Jan 01, 2009
    The 400watt power supply does not tell us much, because we have no idea what the amperage is on the 12V rail(s) etc., which is the important factor.  Please also provide the power supply make and model.  Thanks -> W1ZdoM
My PC when plugged in does not turn on but only powers the fan
Is there beeps coming from inside the tower case? Does the Hard Drive make a spinning sound after about 15 to 20 seconds? It could be a mother board issue, it could be a graphics card issue.
Jan 17, 2013 | Packard Bell Computers & Internet
Computer will not start
Press power button down for 5seconds until the computer shuts down. Remove power cable, press power button down 10s. Connect cable, try to restart.
Aug 17, 2012 | Dell Computers & Internet
Gateway gt4016 desktop, s/n gcm64 110 54982 unit will not boot up, pressing power button, fans starts, yellow light comes on, then shuts down. cleared cmos, pressed power button unit will boot up but...
the cpu could be over heating make sure its secure if you like get some thermal paste from your local pc world put a little on the top of the cpu under the cpu fan and replace fan securely might work be carefull....bonnell
Sep 17, 2011 | Gateway GT4016 Desktop PC
Computer turn on, but when it does it won't POST
It seems like a motherboard issue. It heats up, thus is not able to turn on continuously. You may need to check internal parts embeded on the motherboard llike the fan and processor before you could know what needs replacement.
Jul 18, 2010 | Dell Dimension E521 PC Desktop
Acer Aspire 5520 does not start up, power light blinking green
I think it might be the motherboard, if its not regulating the voltage properly then to much will go thru the motherboard and the fan won't be able to cool things down properly. Eventually then the motherboard will fail and then no video like your having now.
Try these steps anyway just to be sure:
only hook up the AC Adapter keep the battery disconnected. See if it turns on, if you still get a blinking green light then go ahead and turn the laptop off.
At this point, unseat and reseat the memory one stick at a time in each slot one at a time. Try turning on the laptop after each stick reinsertion.
If that doesn't do it then disconnect the hard drive and the dvd drive from the laptop.
Then try turning on the laptop, if you still can't get video then the motherboard is bad and would need to be replaced.
At this point at least you would know for sure.
Aug 19, 2009 | Computers & Internet
Cpu not powering press on button lights flash fans turn for a sec
It a issue with the power supply or the SMPS. Change the SMPS of same capacity and then it should work..............sodeep
Jul 30, 2009 | Compaq Presario 5000 PC Desktop
Macbook - screen white/blank after turning on
Sounds like it could be a corrupted OS; have you tried forcing it to start up with the OS disk, holding down the 'C' key? That's the first place to start...
If it won't start up like that, you probably have a hardware problem. (You can get excellent troubleshooting guidance at: http://www.ifixit.com/Guide/Mac/ ) depending on your level of geekness, and assuming the warranty is expired?
Good luck
dennismacfreak
Oct 05, 2008 | Apple MacBook Pro PC Notebook
ASUS P5GD1-VM Motherboard Logo
213 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
