Question about Canon EOS Elan II 35mm SLR Camera
Screen flashing, won't work when turned on.
The battery on my canon EOS Elan II died, so I replaced it and it's still not working. there's a bullseye looking symbol in the bottom left corner that keeps flashing when i turn it on.
    Top Expert:
  • Canon Master
  • 14,162 Answers
Posted on Jul 18, 2016
SOURCE:
pontelemon
  • 538 Answers
SOURCE: Cannon EOS Rebel G battery light
Film Advance mechanism is jammed and needs service.
Posted on Apr 09, 2009
  • 155 Answers
SOURCE: I have got an EOS Elan II E Film Camera (Cannon).
Hi, all canon EOS digital cameras can take all EF lenses. An EF lens from 1989 will fit a Digital body from 2009.
The newer EF-S lenses will only work with the smaller APS-C size sensors on the cheaper consumer bodies.
Hope this answers your query, please take the time to rate!
Posted on Apr 10, 2009
  • 188 Answers
SOURCE: Canon EOs Rebel, the battery went dead. I replaced
no. check battery contacts for signs of corrosion and make sure cover is latching fully.
Posted on Jul 26, 2009
SOURCE: Sticky shutter blades
Canon EOS cameras manufactured in the late 1980s to early 1990s have an internal foam bumper for the shutter curtain which deteriorates with time, breaking down into an oily black tar. The tar oozes down and gets onto the shutter blades, causing them to stick. This results in the shutter either failing to open altogether or opening too slowly, resulting in blank or unexposed photographs.
cleaning procedure. Take a cotton swab and put a tiny bit of isopropyl alcohol or lighter fluid on it. Don’t drench it - you just want it slightly moist. Rub the tip of the swab on the oily patch, back and forth extremely lightly. You don’t want to apply any pressure, as the shutter curtain is fragile and easily bent and destroyed. Keep lightly rubbing the swab back and forth until the oil is entirely gone. Alcohol is a weaker solvent and so it may take a minute or two of gentle movement to dissolve the oil. Remember to do both sides of the shutter - you’ll have to move the mirror upwards to get the inner side, so don’t get any fingerprints on it. The easiest way to do this is to set the camera into mirror lockup mode (assuming your camera has the ability) and starting the self-timer.
That should fix the camera for the time being. Of course, the foam bumper is still there and continuing to degrade, so you’ll have to do this cleaning every now and again unless you pay to have it replaced. How often depends on your camera. Mine has gone for a year since the last cleaning without problems.
Posted on Feb 26, 2010
  • 129 Answers
SOURCE: My canon eos rebel xs won't turn on. The red light
Check if the battery is fully charged. you may try resetting the Camera to the factory settings. If the issue persists, try power resetting the Camera. To power reset, remove the battery of the Camera and press and hold the power button for 30 seconds and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Posted on Jul 27, 2010
Which battery to use with eos elan?
The EOS Elan uses a single 6V lithium 2CR5 battery, which should be available at most department, electronics, and office-supply stores. If all else fails, you can buy it online from here.
If you need a manual, you may download a copy from here.
Oct 26, 2012 | Canon EOS Elan II 35mm SLR Camera
Manual for canon eos 50e
The EOS 50 is called the Elan II in some parts of the world. You may download the Elan II manual from http://butkus.org/chinon/canon/canon_eos_elan_ii_iie/canon_eos_elan_ii_iie.htm
Feb 05, 2012 | Canon EOS-50E 35mm SLR Camera
I have got an EOS Elan II E Film Camera (Cannon). I want to know Cannon has camera with a digital body which suits the lens attachment of EOS Elan II E.
Mar 10, 2009 | Canon EOS Elan IIE 35mm SLR Camera
Canon EOS ELAN II E built in flash
I cannot locate the parts diagram for the Elan II e but I did find a PDF for the Elan 7. The flash should be very similar, look here;
Canon Parts List
Jan 28, 2008 | Canon EOS Elan IIE 35mm SLR Camera
Canon EOS Elan II 35mm SLR Camera Logo
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Canon Photography Expert? Answer questions, earn points and help others
