Question about Universal Garage Wireless Keyless Entry System
Unable to program my klik2u
I have it the same as my transmitter that will open the door RCL
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    What is RCL? I think the klik2u is the same as clk1. Instrutions for this can be found  @http://www.aaaremotes.com/clungadooppr.h... They can be hard to program. What brand operator do you have? Can you get a keyless for that brand?
5 Suggested Answers
  • 118 Answers
SOURCE: Garage door opener transmitter/receiver compatibility
The old transmitters are 390 mhz and will not program. I need more info on what you are doing to solve the homelink problem. Your vehicle's owners manual should show how to program. Then press learn button and within 20 sec press and hold homelink button that you programmed.
Posted on Jan 30, 2009
  • 3197 Answers
SOURCE: Cannot re-program remote transmitters for garage door opener
If both remotes quit at or about the same time then it is most likely the receiver that has quit. Especially if you have had electrical storms in the area. The receiver is part of your logic board.
Posted on Sep 16, 2009
Testimonial: "Thank you. So does that mean I have to replace my receiver?"
  • 3197 Answers
SOURCE: how do i program KLIK2U remote to my chamberlain
Check out this site. A video and an owners manual.
Posted on Dec 07, 2009
pabloloco
  • 2335 Answers
SOURCE: None of my codes work
Has your KLIK2U worked for your garage door opener before, or are you configuring it for the first time?
If it is being installed for4 the first time, are you certain you garage door opener was manufactured after 1993 & uses a photo-eye sensor? If not, the KLIK2U may not be compatible.
You may find the Chamberlain KLIK2U Digital Manual and the Chamberlain KLIK2U Programming Video helpful.
For more assistance from us, please provide more information about your garage door opener, and we may be able to help you through the programming instructions from the manual.
I hope that helps.
_______________________________________
Chamberlain KLIK2U Manual Download
Posted on May 05, 2010
Klik2u model won't learn from the handheld opener and when I press the learn button my other remotes are inactivated and vice-versa. How can I program the klik2u w/o losingcodes on handheld r
Try erasing all of the codes in your opener. Then try reprograming your remotes and etc. Openers will only accept so many codes. After they reach their max they will accept a code then boot another one out.
Apr 04, 2015 | Building Materials
Tip
Download Chamberlain KLIK2U Clicker Keyless Entry Programming Video
Have you misplaced your Chamberlain KLIK2U Clicker Keyless Entry Programming Video?
Would you like a digital, reviewable, wmv version of the Chamberlain KLIK2U Clicker Keyless Entry Programming Video?
Follow this link (& click FREE) to download a vmw version of the Chamberlain KLIK2U Clicker Keyless Entry Programming Video.
I hope that helps.
_________________________________________
on May 05, 2010 | Kitchen Appliances - Others
How do I check a wireless garage door keypad, to see if it is transmitting?
These remotes don't loose the programming code when a battery goes dead, most likely the remote or the board on the opener went bad, do any other remotes work? You can take the remote to an auto parts store and test it there. (They have a tester for key fobs)
Sep 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
None of my codes work for my KLIK2U garage door opener. How do I get it reprogramed again without a good code?
I hope that helps.
May 05, 2010 | Universal Garage Wireless Keyless Entry...
Unable to program remotes from opener
TRY UNPLUGING THE UNIT WAIT ABOUT 5 MIN. PLUG IT BACK IN CLEAR THE CODES BY HODING DOWN THE PROGRAM BUTTON FOR ABOUT 20 SECONDS.
NOW YOU ARE READY TO PROGRAM A REMOTE TO THE SYSTEM.
HOPE THIS HELPS
Aug 13, 2009 | liftmaster Chamberlain Garage Door Opener...
Program 2004 mercury mountainer garage opener
Verify the hand-held transmitter is operative.
Prepare for programming the universal transmitter by erasing all three channels (hold down the two outside buttons until the red light begins to flash [20-30 seconds]). Release both buttons.
Select one of the three universal transmitter channels to be programmed by pressing the desired button
Hold the end of the hand-held transmitter 25-51 mm (1-2 in) from the front surface of the universal transmitter so that the red light can still be seen
Use both hands to press the hand-held transmitter button and the desired button on the universal transmitter. Do not release either button.
Hold down both buttons until the red light on the universal transmitter flashes, first slowly and then rapidly. Release both buttons when the rapid flashing begins. The universal transmitter has successfully learned the new frequency signal and can be used in place of the hand-held transmitter(s).
If the hand-held transmitter appears to program the universal transmitter but does not open the garage door, the garage door opener may have a code protected or rolling code feature.
To operate, simply press the appropriate button on the universal transmitter. The red light is on while the signal is being transmitted.
IF THE GARAGE OPENER HAS ROLLING CODES---
program as above then------
Train the garage door opener receiver to recognize the universal transmitter.
Remove the cover panel from the garage door opener receiver.
Locate the training button on the garage door opener receiver. Location and color of the button may vary by garage door opener manufacturer. Refer to the garage door opener instruction manual or owner literature.
Press the training button on the garage door opener receiver for 1-2 seconds.
Press the programmed universal transmitter button for as long as the universal transmitter red light flashes (1-2 seconds). Release the button and re-press the button to confirm that the universal transmitter is trained to the receiver.
The garage door opener should recognize the universal transmitter.
Apr 01, 2009 | 2004 Mercury Mountaineer
Universal Garage Wireless Keyless Entry System Logo
560 people viewed this question
Top Universal Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you an Universal Building Material Expert? Answer questions, earn points and help others
