Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Water drips from underneath icemaker and freezes in bucket
Whirlpool ED5FHEXN... Water is slowly dripping from under the front of the icemaker until the water begins to freeze. Have not noticed any Teflon specks in the ice cubes. Is there a seal that can be replaced or do I have to replace the complete unit?
  • 1 more comment
  • rick_renshaw Jan 07, 2009
    It appears the unit has a leak because it is not overfilling. The unit is still making ice cubes in the proper size. But it has slowed down the production of cubes significantly since the leak started. The water is dripping just below the first cube cell closet to the front of the freezer. I'll followup on your suggestion to take it down and test for the leak at the sink. Thanks.
  • rick_renshaw Jan 09, 2009
    Excellent help. Thanks a bunch!
  • J Mood May 11, 2010
    Is the unit leaking or is it being overfilled? Is the refrigerator level?
    If it is not being overfilled, you can remove the unit and inspect it to determine exactly where the leak is coming from. First, there is probably a 1/2" or so rubber tube that carries the water though the back of the freezer, make sure it hasn't slipped out of place. Unplug the refrigerator, remove the ice bin and loosen the two screws on the tabs above the ice maker. Push the ice maker up over the screws. Pull the 4 or 5 conductor plug out that connects the ice maker to the back or side of the freezer. Fill the ice maker mold in the sink and see if you can find the leak.
    Scholar:
  • 31 Answers
If you find the offending part of the ice maker, I've had good luck with these guys when ordering spare parts. Here is a link for your model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133512
Posted on Jan 07, 2009
What would cause my ice maker to leak into the plastic ice bucket?
The most likely cause is the fill valve is leaking and causing the ice maker to overfill. Try a new fill valve. Usually located on the rear of the appliance. (where you hook the water line to).
May 02, 2014 | Whirlpool GZ25FSRXYY
Ice maker is leaking water at the rear of the ice maker, somewhere around the water inlet. Water is dripping slowly and building up an ice ***** BEHIND (outside) the ice cube storage bin AND inside the...
Hello,The reason all the ice freezes together and you see icecicles forming from the icemaker,is going to caused by the water inlet valve on the back of the refrig.is not fully closing but instead it's seeping water through it and dripping into the ice storage bucket. To stop that from happening the water inlet valve would need to be replaced.
On refrigerators that have a built in water filter,alot of times their will be 2 water valves and the one that is bad causing water to seep through it will be the one called the SECONDARY valve.
GENE
Sep 30, 2011 | Maytag MSD2454G Side by Side Refrigerator
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My icemaker of my Kenmore THI21S3W leaves chunks of ice, (apparently from dripping although i can't detect the drip) right under the center of the icemaker - not near the inlet - does it need replacemnt or...
Good day,
The usual cause is a the water valve in the bottom back of the machine not shutting down completely after a fill cycle.
This causes it to flood the well and drip into the bucket. It'sa very common problem.
If that does not solve the problem, it is a conventional ice maker made by Whirlpool, and is available at most any appliance parts house.
No loss here because installing a new valve with a new ice maker is pretty standard in the appliance repair industry.
Apr 17, 2010 | Kenmore 64802 Top Freezer Refrigerator
Whirlpool duet front load washer flashing f 21
The instructions to fix this were great and did the trick, would add a few suggestions:
1) Removing the front panel just under the washer door can be tricky, it is secured underneath by 3 1/4" hex screws, you may need a special hex driver or ratchet to remove (can get at home Depot for $4)
2) Make sure you check the tubing from the drum and out to the drain they can be clogged to
3) Twist open drain filter slowly, water will come out so put a heavy duty garbage bag underneath to catch water
4) When replacing filter make sure to line up notch at the top of filter with the groove inside and then slowly screw clockwise back in until tight
5)Make sure to replace front cover tightly, there is a drip fuse that won't let the washer run unless front cover is back on.
Socks are the most common thing to be found.
All will take about 10 mins.
Mar 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Icemaker keeps freezing up after a couple of weeks of using then it becomes clogged with frozen ice int mechanical part of the icemaker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Kenmore icemaker seems to be leaking water under the icemaker and it drips and freezes
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 10, 2009 | Kenmore Refrigerators
Kenmore Refrig 51562 Side By Side; Icemaker leaks water underneat
you are going to have to replacwe the solinoid valve for the icemaker mbecause its leaking by
Feb 25, 2009 | Kenmore 51562 / 51564 / 51569
Water leaking underneath icemaker, dripping into ice tray
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the first one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Feb 20, 2009 | Amana DRS2462B Side by Side Refrigerator
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
134 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
