Question about Fisher 9925 Shelf System
Fisher DAC 2403 M-Error message
Not using the unit for a while, it was not recognizing that there were cds in the carousel. I removed them manually and reset them one at a time, but now when it plays a cd, it does not put it back in its place and gives a m-error code on the window. I turn it off and back on, and it resets the cd so I can eject it. Any help would be appreciated.
5 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: m-error
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly.
The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Sep 06, 2008
SOURCE: disc will not eject nor play on fisher studio 24 management syste
remove the screws to your cd player and take this apart and remove the disk by hand and put system back together. It should work after that. I am a former tv technician. just be careful how you take it apart to put it back together again. do not plug unit in untill it's all done to avoid eye damage from the UV rays.
Posted on Mar 04, 2009
SOURCE: Fisher radio TAD-9415 made in 1995
Check firstly, if your radio is Fisher Tad-9415 you are in ****! The only chance which you have it is to make it repaired by the company. The price of repairing: $750 us address I do not know it. Sorry. But, keep really because the casset reader and the radio FM always works. I would pay $1000 us to renovate this radio if I was you! I hope that you is not too much over! Three million times sorry.
Posted on Jun 07, 2009
SOURCE: I HAVE A FISHER TAD-9415 SYSTEM AND THE CD WONT
hope it is not too late but have had the same problem, just got around to open up the case and found the problem and was able to fix mine and now it plays fine. My problem was with the cd turn table it was not be feeding the cd into the player causing the m-error..
Posted on Dec 11, 2010
I have an old Aiwa stereo with a 5-CD changer. The remote control has RC-7AS05 on it. How can I program the CD player to play the CDs continuously?
Press the RANDOM/REPEAT button and watch the unit's display. There will be a graphic changing to show the different functions: Disc repeat....All Repeat.
Try out the different modes unit you find the one that plays all the discs in the carousel.
Sep 16, 2014 | Aiwa Audio Players & Recorders
The CD drawer won't open - gives error 0101
If it is a carousel-type unit, you probably can disassemble it to expose the tray and allow removal of your CDs.
Jun 29, 2017 | Sharp CD-C622 CD Shelf System
Show picture of carousel rotary for hp 2840
Carousel rotation motor error, only professionals can do this activity,, Pl submit the unit in service center,, online support not suggestible..
Nov 16, 2011 | HP LaserJet 2840 Printer
I purchased a used Wurlitzer 1015, question When selecting number 51 is a code number 82 and does not play can you explain me this, what the problem is thanks
The number of Cds in the carousel can be set on the Credit unit to stop it playing fresh air if for example you only have 50 Cds and not a whole 100. Sounds like yours is set to 50 so won't play anything over 50.
I 'think' this is what you do.
On the computer credit unit...
Service Switch ON...Press LT button.
Press 5 on the keyboard once.
Enter 0000
Service Switch off.
Press LT or turn machine off/on.
Aug 03, 2011 | Wurlitzer Jukebox 1015 One More Time...
I just recieved a system fisher dac-9345 and the cd changer wont eject the cds what could be the problem
Sounds like you've got a problem with either the Drive Motor, Drive Controller or Drive Belt.
It could be an easy fix but it depends on the where the fault is.
Does it make any noise or effort to open the tray?
May 12, 2011 | Audio Players & Recorders
Need remote codes for AIWA CX ZR 525u Cd/Tape Radio Deck 5 Disk
Hi. The carousel loading belt probably needs replacing - that's why you are "helping" it.
You could try cleaning the cd lens too if it's not selecting an reading cds.
HTH
Replacement belts and laser units are on ebay.
Nov 02, 2017 | Aiwa Audio Players & Recorders
JBL 6 CD AM/FM Cassette Audio has CDs stuck inside and won't play or eject them. How can I get them out?
I've had this happen before with car stereo's uh i just normally unscrew the screws out of the top of the player to where you can get to the tray or slot for the cds and force the cd tray or the cd itself out but be careful and not break the cd this might work it usually does for me
Aug 17, 2009 | JBL MCDC100 6-Disc CD Changer
Fisher 9925 Shelf System Logo
1,060 people viewed this question
Top Fisher Audio Players & Recorders Experts
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
