Question about Honeywell Programmable Thermostat Heater
How to adjust the temp drop of desired heat setting. for instance
Set temp at 71 would like room temp to drop to 69 before stat calls for heat again
  • 61 Answers
Set temp to 69!
Posted on Jan 02, 2009
How to adjust thermostat
How to Adjust Honeywell T6360b1028 Thermostat? ' DIYnot Forums
www.diynot.com > Forums > How to... > Plumbing and Central Heating
Unless the thermostat is faulty, the point where your 'stat clicks is your actual roomtemperature. If your 'stat doesn't 'call for heat' when set to 18 and your room ...
Nov 01, 2015 | Honeywell T6360b1028 Room Thermostat
I cannot get my thermostat althc014 to turn down by its self when room tempreature is reached
How To
Set The Temperature
The reason the stat is coming on during the night/ always
being on is setting number 5, there are 5 settings on the Salus
is the time you want heating on eg, 07.00 and set the temp (20)
is the time you want it to go off eg, 10.00 and set the temp (10 this
will turn it off)
3 is the time to come on an evening eg. 17.00
4 is the time you want it to go off eg,
23.00 and set the temp (10 this will turn it off)
5 the problem
many people have is that they do not set number 5 correctly, this is a
night/ frost stat and if you don't set the time and temperature same as 4
ie, 23.00 and 10*c then the heating will stay on.
How To Set The Time and Date On Salus Programmer?
1.Press the
Set and Select buttons simultaneously to enter the clock setting mode.
2. By using
the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock.
Once selected press "SELECT".
3.The "HOUR"
will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the
desired time. Press "SELECT".
4.With the
"MINUTES" now flashing adjust with the arrow keys to the correct
minutes. Press "SELECT".
5.Now the
"YEAR" will need adjusting. Again use the arrow keys to change and press
"SELECT".
6.Now adjust
the "MONTH" with the arrow keys and press "SELECT"
7.Next to
change will be the "DAY OF THE MONTH" again with the arrow keys change
and press "SELECT"
8."dLS" will
now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF"
use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Hope this information is what you need to operate your unit.
Oct 01, 2013 | Computers & Internet
Room Stat Overides Programmer
It sounds like its working as a frost stat ,which will fire the heating when the temp drops with the heating not being on , this to stop house from freezing up .
Oct 26, 2012 | Acer Aspire Computers & Internet
I have 2 goodman heating systems. one for upstairs and one for downstairs. The downstairs works great. With the same temp settings on the upstairs, The blower kicks on and you hear the the flame kick on...
i have seen this just the other day customer called and there thermostat would not maintain temp... changed batteries and after five mins did it again... couple of things need to make sure you have fresh batteries if it takes them in thermostat. also try overriding program by pressing the hold button and set where you desire see if it works then... if it still fails to maintain you need to make sure the unit is not running when it is suppose to be off... if the fan is running and the thermostat is not calling for heat or cool then it is possible the flame sensor on the heater is bad or needs to be cleaned... to be honest based on what you are saying sounds like you got two different items going on....
a sure way to test if your mechanical inclined is take the t-stat apart jump the r terminal to the w terminal go to unit and unplug for 10 seconds and plug back in if everything fires up and stays going you 100% have a thermostat issue...
Dec 31, 2010 | Goodman Heating & Cooling
The heater will not kick on. It's a programable 7 day that reads 69 degrees and if I arrow up to 72 degrees, nothing happens
Change Temperature Setting Until the Next Program Period (Temporary Change)
? Press UP Arrow or DOWN Arrow until the screen shows the desired temperature setting.
NOTE: The temporary temperature setting is displayed for about 3 seconds and then the room temperature is displayed.
Temporary appears in the display. The setting cancels when the next program period starts or when
you press RUN PROGRAM.
Change Temperature Setting Indefinitely (Hold)
? Move the System switch to the desired position (Heat or Cool).
? Press HOLD TEMP then UP Arrow or Down Arrow to change your setting if desired. (The display changes from showing the setpoint
temperature to room temperature after approximately three seconds).
? To cancel Hold press RUN PROGRAM.
The downloadable manuals for this t-stat are here, and the addendum, here. Page 17 and 18 detail thermostat operation I have copied above. It has graphic representations of keys that do not copy over very well, so if you have questions about the steps above, you should view the manual in the links provided above.
I hope this helps! Please take a moment to rate my reply - thanks!
Dec 23, 2010 | Honeywell CT3600 7 Day Electronic...
Lost program instructions freezing
Hi, on a programmable stat, you should be able to raise the temp with the arrow and then push hold temp. feature. This will hold the desired temp and get you heat unless you have a stat problem. Try this and let me know the settings.If this didn't work, make sure the stat is in the auto-heat posistion. Push program and set the time.press again and set the day of week. Repeat this step and set the desired temp for each day of the week and week-end and push run program.You should hear it click on. It takes a min. or so on heat as there is a delay. Make sure the batteries are strong as they run the program. Let me no. Best of Luck, Sincerely, Shastalaker7
Dec 04, 2009 | Honeywell Programmable Thermostat Heater
My honeywell central heating system turns off on its own. I set the room temp., the heating system reaches that temp then just turns off. The temperature drops and the system does not kick back on again to...
Hi, Just to let you know I have repaired central Heat & Air systems for 33 years and Have seen this problem on many occasions. Lets see if I can save you so many trips.It says you have a programmable stat? On this stat and on a mechanical stat, they have what is called a heat anticipator that controls how many and how often your thermostat turns you're unit off and on and how long it cycles after the stat is satisfied. If you have ever seen under the cover of a mechanical stat, ( mercury switch type) you will see a dial with an arrow with numbers as .1, .3, .4 1.0, or .15 to 1.0 amps.Some are fixed and some are adjustable. On a digital stat, you will have to get into the program and see what the heat anticipator is set on. They come from the factory at .4, but to really find out what you'res should be it takes an amprobe to do this. The setting you need is what you're gas valve requires.I am sure I have lost you, but I am just giving you a little food for thought. If you can get into you're program and set this to .4, great. If the problem continues, your anticipator on this stat is more than likely, shorted, which would require you to buy a new stat.With a shorted anticipator, it will seem to be working like you say, but when satisfied, the temp.keeps falling until you reset power, then it fires and repeats this. Change the stat. If this is central heat and air, just follow red-rc which will have a red jumper to rh for heat, white to w, green to g=fan, and yellow or blue to y = cooling. If you have central heat only, you will find 2 wires red and white.Red to rh with jumper still installed to rc and then white to w.This is quite a long explanation, but I wanted you to know a little more then the next guy about your stat. Please let me know.
Sincerely,
Shastalaker7
Nov 12, 2009 | Honeywell Programmable Thermostat Heater
Housesitting. RTH111B model. I cannot keep the
That is a NONprogramable T-stat. There is no program to overide, therefore there is no need for a "hold" option. To set the temp, place the switch on the side marked
COOL
OFF
HEAT
to the desired setting, and push the up down arrows on the front until the display shows 80.
The DISPLAY will revert back to the current room temperature within a few seconds, and will keep the unit on until it reaches the desired temp.
The set temperature remains at 80, it just shows the current room temp.
Aug 31, 2009 | Heating & Cooling
I have a 3 ton Coleman heat and air pump and when I turn the air condition on the heat strip comes on at the same time
If you are calling for heat and the thermostat is set for 2 degrees higher than room temp, the heat pump and strips come on.
When the room temp and stat temp are less than 2 degrees the strips turn off.
That is, unless the installer wired the t-stat for the strips to stay on.
If they are coming on in the air/cool mode then you have a bad heat relay or a t-stat wire shorted.
Mar 11, 2009 | Coleman Heating & Cooling
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
101 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
