Question about Alesis TransActive Mobile PA System Speaker System for iPod TRANSACTIVE
My Alesis transactive mobile PA system will not charge. I plug it in and the charge light does not come on???
  • Tedlie May 13, 2009
    We bought Alesis Transactive Mobile PA, and fresh out of the box, it wouldn't charge, so we exchanged it, and the next one had same problem.  The problem with both units: Only 2 of 3 green LEDs showing charge level were lit, and the charge indicator light never came on.  We returned both faulty units without experimenting to run down the battery and see if it would charge, because instructions emphasized to fully charge before use, and we couldn't get either one to show full charge, after all night for each one.  We are waiting to receive a third unit.
Surprisingly, there is a little compartment just in the outtlet intake in the AMP, and the 10amp fuse was burned. I replace the fuse for a 10amp new one and everything work great. It charge. The little green light of charging, turns on.
Posted on Jan 03, 2011
Did you find the solution to this problem?I'm having the sa e issue, please let me know what you did.
Thanks
Posted on Jul 21, 2010
Were is the outake intake and 10 amp fuse sited .cheers
Same quest I had. So, with flashlight, look inside the 3 prong AC receptacle. It's subtle, but on the lower inner "shelf" of receptacle can pry outward toward you with jewelers or thin standard screw driver. Fuse holder and fuse popped out with a hard pry. Does it look burnt? Mine ohmed out okay, so must be some other problem. 8 sec of charge light when 1st plugged in; then no light. Works plugged in but not unplugged. Idled a year in the garage. My fuse was 750mA 250 (in America, 110V)Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off. -Cheers
Dec 23, 2012 | Alesis TransActive Mobile PA System...
Where can i get parts for alesis
Doubtful you can find replacement parts it, but a clever electronics guy can bypass the switch (or put on a new one) and make it so it powers up when you plug it in.
Nov 05, 2012 | Alesis TransActive Drummer Electronic Drum...
My Alesis Transactive Mobile PA is not working. The charging light illuminates only when initially plugged in, then turns off. I'm thinking the battery may be dead even though I've only used t
Mine works when plugged in, but dead when not plugged. Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off.
Sep 15, 2012 | Alesis TransActive Mobile PA System...
Battery not holding charge on Alesis transactive pa system. Power cord connected and keeps turning off.
If the battery is old, say three years, it may be worn out. Fully discharging batteries or using them beyond where they have noticeable loss of power results in reverse charging the weakest cell which then often shorts rendering the battery un-rechargeable.
Aug 01, 2011 | Alesis TransActive Mobile Speaker PA...
My Alesis Interactive Mobile Amp seems to have a dead battery. I was keeping an eye on the charge lights, and when it went from 3 green lights down to 1, I plugged it in to charge the battery back up. ...
change the battery, its quiet easy, but anyhow, now warrenty whatsoever!
you need:
a) one hex screwdirver size 5mm
b) 1 phillips screwdriver size 2
c) 1 replacement battery, maintenance free lead battery block, 123V 7.0AH Type 1270
d) some pieces of 1mm thick foam rubber (4 Strips 150mm, 4 strips 65 mm and 4 strips 95mm, 8-10mm wide would be original, but quiet anything would do it)
e) some glue
f) depending on your expertnes, 20 to 40 minutes time.
... yes thats all.
here we go
DISASSEMBLY
1. lay the unit on to back
2. unscrew the edge plates on the front side (4 pieces, 3 screws each, hex)
3. remove the three edge protectors
4. unscrew the front panel (8 screws, phillips)
5. pull the frontpanel gently up by 2 cm (aprox 1 inch), will be enough
6. lift the grill without bending and remove it
7. unscrew the main speaker (4 screws, phillips)
8. carefully lift up the main speaker
9. look thru the hole, you will see the battery, mounted by 4 screws (phillips again). Unscrew
10. unplig 2 battery leads
11. lift out te battery
ASSEMBLY
1. glue some of the foam rubber arround the new battery, take tie old battery as sample.
2. slide in the battery
3. connect the leads to the battery, the red goese to te red marked pole. Importand
4. Mount the battery holder 4 screws phillips
5. slied in the speaker, mout it wit 4 screws, phillips
6. mount the grill without bending
7. siled the frontpanel back into position and screw ist (8 screws, phillips)
8. bring the edge protectors back into position
9. Mount the edge plates (3 hex screws each)
10. put it back on the weels and load your battery. Testrun.
11. have a beer for me and enyou your music.
May 30, 2011 | Alesis TransActive Mobile PA System...
I have an alesis transactive mobile, which persistanly blows the 3.15a glass fuse. can anyone help........? Thanks Jamie
Generally a blown fuse is an indication that something is wrong and needs to be fixed.
If it is happening while the unit is in use, it may indicate power leakage to earth, which could be a safety hazard.
Or it could be drawing too much current because of a circuit fault.
If it happens when the unit is first switched on it could be be because of the initial power surge.
All three conditions could be contributing to some extent.
It should probably be checked out by an electronics technician.
If it only ever blows the fuse on switch on, fitting a slow blow fuse could keep it in service, and may appear to solve the problem, but i would still consider having it checked out and a component fitted to limit the initial current surge, as was fitted in most cathode ray tube computer monitors.
Jan 29, 2011 | Alesis TransActive Mobile PA System...
Battery has died how do I replace it?
you need:
e) some glue
... yes thats all.
here we go
DISASSEMBLY
ASSEMBLY
Jan 18, 2011 | Alesis TransActive Mobile PA System...
I have an ION Tailgater which doesn't seem to be charging. The unit power doesn't have to be on whilst charging, but approximately five seconds after plugging in to charge, the charge light goes out, and...
I just bought four units, 2 of them work fine but the other two have problem, but one of the unit did get charged up even without the charger light on. I switch on the unit, leave it plug in for a few days and the unit come back charged. I try with the other one, but it is not working.
Dec 20, 2010 | ION Audio Tailgater Portable PA System...
Alesis TransActive Mobile PA System Speaker System for iPod TRANSACTIVE  Logo
1,338 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
