Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Low battery on hunter 44422
I need to know how to change the battery on a hunter digital thermostat model 44422
I have the same unit, 44422. The base has four clips, two on the top and two on the bottom. The front portion is clip-on. Try to push on the base's bottom and pull off the front portion, like opening a book. After the battery replacement you will have to reset the unit trough the little reset hole. Otherwise, the ''LOW BATTERY" will not go away. Yes, you will have to reprogram the unit.
Posted on Jan 25, 2009
Hi I have this model 44422 thermostat. The battery is low. I am not able to open the Front panel. I see you have given instructions. But unfortunately I could not follow this . What ever I could understand with that I tried to open, I could not open. In the Manual there is no diagram to understand this. can you pl help me with any other way?Murali Jambu
Posted on Nov 10, 2012
How do I know if my hunter thermostat is still good
It is faulty. Shut the power off and get it replaced before you get hurt.
Feb 24, 2015 | Hunter Dryers
Why won't thermostat turn on after I changed the batteries?
I think you may have the model # incorrect, However if you have a thermostat as in the type that are hand held, polarity of the batteries is the 1st thing I would check, then test them for proper voltage, corrosion will often interrupt that small of a voltage, clean the terminals and test it .
A wall mounted like a central HVAC system typically will not require batteries to operate, this is for memory and they will work fine even if no batteries are installed, however there are battery powered stats too, meaning non parasitic type that not powered by the transformer in the air handler.
I will include a basic drawing of a residential HVAC thermostat to show you how the 24 volts powers most thermostats.
ome > Air Filtration > Air Cleaners and Purifiers > Hunter Air Purifiers > Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer
Item #: hun30124 892f1d0d-b50f-49aa-8079-70d2dc34eb2b.png
Jun 07, 2014 | Hunter 30124 Air Conditioner
I HAVE CHANGED MY BATTERIES ON MY HUNTER THERMOSTAT AND RESTET IT BUT IT STILL GOES BACK TO DFAULT AND AND E STILL REAPPEARS AND MY AIR WILL NOT KICK ON
http://hunter-thermostats.com/hunter_manuals.html - This site has the owners manuals for a list of Hunter thermostats. You will need your Model Number.
Apr 03, 2011 | Heating & Cooling
How do I change batteries in a Hunter airconditioner thermostat
You should be able to just pull off the front cover. Look around the wall and there should be guides telling you too either pull the bottom out first or somehting like that. The batteries should be just behind the front cover.
Dec 12, 2009 | Hunter 30124 Air Conditioner
I believe the digital hunter thermostat say energy moitor 1
Find the 5-digit model number (example 40170) on your thermostat. Go to http://www.hunterfan.com and paste the number into the search field at the top of the page. If Hunter still supports this product, you should be taken to the support page for it which has a link to the product manual PDF.
Oct 15, 2009 | Hunter Fan Company 5/1/1 Programmable...
Thermostat
By resetting I found out that there was low battery, but now I can't get the face of the thermostat off to put in a new battery. Manual got displaced.
Jul 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
I have a hunter programable thermostat model number 44422 and the condenser outside will not kick on The fan is working inside but I have no cool air(air conditioning) I do not understand why the outside...
The outdoor unit has failed in some way. This is probably not the thermostats fault. You can check the breaker for the outdoor unit by turning it off and then back on. If this does not work, the problem is most commonly one of the following issues. All of which should be done by a professional because the danger of electrocution.
1) Bad Start/Run capacitor
2) Bad Compressor
3) Bad Exhaust fan motor
4) Combination of some or all of the above.
Jul 03, 2008 | Hunter Heating & Cooling
Hunter therm
try to reset. if doesn't work properly, repalce the thermostat.
Jun 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
1,847 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
