Question about Audiovox FPE3206 32 in. LCD Television
When turned on it Flickers
I Have an Audivox fpe 3206 HD LCD When I first turn on TV it flickers real bad like it is being turned on and off real fast. This stopes after about 1 to 2 Min.
  • tiffguam Jan 08, 2009
    Mine started off flickering for 1 or 2 minutes now it flickers for hours!
  • wgslack Apr 28, 2009
    the flickering sounds like a machine gun. even with no sound turned on before i turn it off, it is really loud when it flickers in/out as the picture gradully comes in. TV is about 2 years old and more than likely out of warranty. please HELP.
    Problem Solver:
  • 13 Answers
Mine started out like that, now flickers about an hour before it comes on. I don't turn it off anymore, it'll burn out one of these days and I'll get a better TV.
Posted on Jul 12, 2009
Samsung ln40b550k1f screen flickers on and off
When the screen flickers on and off it usually comes from the power supply or backlight inverter being bad. For your TV, the backlight inverter and power supply unit are combined. As you can see in the picture attached it's the white part on the right side that has gone bad. You will need to replace that board. LN40B550K1F Samsung LCD TV Repair Guide
Mar 11, 2013 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
Sep 14, 2012 | RCA Televison & Video
Samsung le40f71bx picture flickers on and off with hd source
I've had similar for a long time, now the picture only lasts a few minutes or seconds. Have to turn the TV off, wait 5 minutes, turn it back on. That's with Sky HD. Used to be the same with SCART but I don't use that any more, and I get it with the Wii on Component. However HD DVD and Blu Ray players are no problem!
See my post here - http://www.avforums.com/forums/lcd-led-lcd-tvs/1622157-samsung-f71-flashing-pattern-fault.html
Way out of warranty but really just need some repair expert to tell me what needs fixing. Taking the cover off there are very few components and look easy to replace, and seen some on ebay. A fix from Samsung would be vastly in excess of the value of the TV.
Apr 21, 2012 | Video Game Consoles & Games
Samsung Lcd tv-sound but no picture-comes back after being off for long
hi i have condensation in the back of my samsung lcd tv it turns on but it just flickers anyone can help thanks
Feb 29, 2012 | Samsung LA46A550 46 in. HD-Ready LCD TV
WHEN THE TV IS PLUGGED IN AND TURNED ON IT FLICKERS IS THIS A POWER SUPPLY ISSUE AND IF SO WHAT IS THE SERIAL FOR THE POWER SUPPLY
The flickering you describe is most certainly a bad capacitor in the power supply. find a hobbiest or TV tech to do this for you. These TVs require lots of patience to remove the back cover and removing the power supplies. Good luck and thanks for asking.
Dec 19, 2010 | Audiovox fpe 3207 32 in. LCD Television
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
LCD TV flickers non-stop
More likely to be bad LCD controller, see sample here: notes: I removed the cover from the board. http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: there are more than one version of the board, http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
Be careful when remove the back cover! the switch assembly is attached to the back panel, do not yank too kard to remove the back.
Jan 06, 2009 | Westinghouse LTV-32w3 HD Television
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Audiovox FPE3206 32 in. LCD Television Logo
485 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
