Question about SimpleTech SimpleDrive   STI-USB235/160 160 GB Hard Drive
XP will not access discmgmt.msc
Babb ,your solution will not work. my external is plugged in,turned on, but when typing in "run" box I get a window saying "unable to find discmgmt.msc" try search ! any suggestions? thanks for your fast response. Keith
    Novelist:
    Scholar:
  • 104 Answers
Ok try this, Right click on my computer, click on Manage! You'll see, Computer management!! on the left pane under storage, you'll find disk management!! And its diskmgmt.msc not discmgmt.msc, sorry! regrds, babb
Posted on May 07, 2007
SOURCE:
My computer just stop to producing sound from speakers even the welcoming window xp sound,
The audio driver might have been corrupted. You just need to download the appropriate audio driver for your motherboard. Go to the Device Manager and install all missing drivers for "Unknown Devices". Either connect to the internet or use the driver disc which came with your motherboard.
For those who doesn't know how to access Device Manager, please follow the steps below.
For Windows XP:
Start -> Run -> Type devmgmt.msc (in the box) -> Right click Unknown device -> Properties -> Driver tab -> Update driver
For Windows Vista and Windows 7
Start -> Type devmgmt.msc (in the start search box) -> Right click Unknown device -> Properties -> Driver tab -> Update driver
Hope this helps.
Aug 27, 2011 | Dell Dimension 8400 PC Desktop
Tip
USB,Ipod and external hard drive not recognized in laptop,desktop.
Hi there,<br /> Follow this steps,if it is not working then post back i have 3 more steps left.<br /> <ol> <li>Click Start</b>, click Run</b>, type <span>Devmgmt.msc</span>, and then click OK</b>. The Device Manager</b> window opens. <li>Expand Universal Serial Bus controllers</b>. <li>Right-click a USB Root Hub in the list, and then click Properties</b>. The USB Root Hub Properties</b> dialog box is displayed. <li>Click the Power Management</b> tab. <li>Click to clear the Allow the computer to turn off this device to save power</b> check box, and then click OK</b>. <li>Repeat steps 3 through 6 for each USB Root Hub in the list. <li>On the Action</b> menu, click Scan for hardware changes</b>. <br /><br />Windows XP recognizes the new device. <li>Close the Device Manager</b> window.</li></ol> Hope this helps.<br /> Cheers!!
on Jan 05, 2011 | Computers & Internet
Sound is not working
You just need to download the appropriate audio driver for your motherboard. Go to the Device Manager and install all missing drivers for "Unknown Devices". Either connect to the internet or use the driver disc which came with your laptop.
For Windows XP:
Hope this helps.
Aug 14, 2011 | ASUS Eee PC 1000H Laptop
No audio from PC
You just need to download the appropriate audio driver for your motherboard. Go to the Device Manager and install all missing drivers for "Unknown Devices". Either connect to the internet or use the driver disc which came with the motherboard of the computer.
For Windows XP:
Hope this helps.
Jul 17, 2011 | Computers & Internet
Need drivers for external hard drive (wdbaaf00-10hbk-01)
Hard drives do not require drivers. If you are using Windows, the drive will not show up until it is formatted. You can access the Disk Management interface to format the drive by entering compmgmt.msc into the search bar in the Start menu in Vista/7, or in the Run dialog box in 2000/XP.
May 13, 2011 | Computers & Internet
Windows cannot read my external hard drive anymore. It is tells me to unitialise it, and windows cannot even help because of an I/O device error.
Please check the External Hard-drive to some other computer
it it is working fine then check the services and turn on the plug and play
start - run - type services.msc
select the look for Plug and Play
Jan 03, 2010 | Seagate FreeAgent Pro 1TB External USB...
I try to connect external HDD hatachi 160 cannot detect.System used xp.
go to start and run. In the command box type
diskmgmt.msc
Click Ok
In the Managament Console you should see your disk. You may need to format
it, or assign it a drive letter.
OR
UPDATE YOUR WINDOWS XP TO XP3
Sep 25, 2009 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
I am not work with my gpedit.msc
Unfortunately Windows XP Home edition does not have group policy editor and can not connect to a domain. You will need to upgrade to XP pro in order to have this functionality.
Jun 11, 2009 | Microsoft Windows XP Home Edition
Won't recognize on windows XP(SP3)
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 10, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
External hard drive in winows
My guess is that the pc is trying to use a drive letter that is already taken. Make sure the drive is plugged in. Goto Start -> run -> type compmgmt.msc and hit enter. Click on disk management. You should see the drive in the list. Right-click the external drive and click change driver letter. choose a letter that is not already taken. that should do it..
Jun 13, 2008 | Microsoft Windows XP Home Edition
SimpleTech SimpleDrive &#160;&#160;STI-USB235/160 160 GB Hard Drive Logo
345 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Joaquim Martins
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
