Question about Health & Beauty
Homedics hbm-300 hi there!i read before that you opened from zipers the hbm-300.Did you saw any fuse there?Where exactly is it?My hbm-300 stopped working after 10 only minutes. kampats1986@yahoo.gr
    New Friend:
Hi mrtoupsclassroom on youtube
had to open up a used unit b/c it was crunching at the top and not coming down.
there is a string attached to all three zippers in back in the inside of the unit...............use a pick to fish it out and then cut it
on mine, I noticed a bent switch lever pulled it up out and bent it back using the upper switch as a model...............thing works great now............will grease it before putting it back
hope this helps..............email with questions or comments:
Posted on Jul 13, 2014
After you get the cover unzipped and removed, remove the screws around the perimeter of the back and separate the two halves. Near the bottom, where the power cord enters, is a small box about 2"X3", it's cover is held in place by three screws. If you remove the cover you'll see a small circuit board and on that board is fuse that may be blown, unfortunately the fuse is soldered in place and not just a snap in type. Hope this helps.
Posted on Nov 03, 2009
  • 2 more comments
  • brian toups
    brian toups Jul 13, 2014
    mrtoupsclassroom on youtube:
  • brian toups
  • brian toups
    there is a string attached to all three zippers in back....fish the string out and cut it then upzip
  • brian toups
    the lower switch on mine the lever was bent.......used upper one as a model....rebent and will lube....no longer does it get stuck at the top and no crunching works like a champ...nice unit....
    Problem Solver:
  • 5 Answers
When i unzipped the whole thing and pulled it out, i saw 2 wires, and they were disconnected so i reconnected it then i turned it over to make sure that nothing else was out of place, then i turned it on and wala it worked also you might want to look at the remote, because there might be a big knot in the wire and then idk how you fix that.
Posted on Jan 01, 2009
Repair manual for Homedics HHP-300
Request the manual directly from Homedics.
Oct 09, 2016 | Homedics Health & Beauty
Use Manual Garment Steamer Model PS-300
If you have the Home Pro Professional Garment Steamer PS-300 from Homedics, the Homedics website has the manual on their support page. Go to http://www.homedics.com.ph/instructionbooks/ .
then use the drop down menu to select the PS-300. Click on Download to get the instruction book. Note: the file is a PDF, so you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Jan 20, 2014 | Irons
I've plug the 110-v Homedics massager into 220-v. It stopped working. Is there a fuse for this product?
The same case happned with me, I wrogly used it with 220V in India - my model is Homedics Shiatsu MCS-360H :-(
I can not see any thing burnt inside the chair ( I opened it and exmined ) but there is no light in attached remote - Kindly share the solution if you have any at agnihotry@gmail.com
Regards
Abhi
Jun 23, 2011 | Homedics Back Massager with Heat
My blood pressure monitor is reading 20 points higher than my real blood pressure. What can I do to calibrate it to be more exact.
Contact the HoMedic's Consumer Relations Dept @ 800-466-3342 Mon - Fri, 8:30am - 5:00pm ET, they can help you.
Keep in mind, that improper placement of the wrist cuff can cause higher or lower readings, than what they truly are. Also, not keeping your arm at heart level can cause an inaccurate reading.
Mar 01, 2011 | Walgreens By Homedics Automatic Blood...
My very old Craftsman 10" Table Saw does not power on. While rip cutting some plywood, I errored and caused the blade to bind. Before I was able to power off the saw, the motor stopped. I thought I had...
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Aug 13, 2010 | Craftsman 10" Table Saw
LG HBM- Bluetooth- need to find how to link
Strat with headset 'OFF' then hold power button until light flashes blue and red or solid blue, then search for headset on phone, pass key should be 0000, 1111, 1234.
You can get the manual by searching for the FCCID, which should be in the headset https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Apr 30, 2010 | LG HBM-760 Bluetooth Headset
Ilectrical problem
If I only used it for 10 min. and it stopped working? I would quickly throw it back in the box and find a store that sells them and demand a replacement. Or just buy the same exact model and then return the broken one to the store with the same reciept.
Jan 01, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
What is the passkey for LG headset HBM-300?
the passkey is 0000 (that's four zeroes)
this is the default passkey for any LG headset.Hope we are helpful.
Thank you.
Dec 19, 2008 | LG HBM-300 for VX9800 Wireless Headset
Hbm-300
hbm-300 doesnt support nokia phones.
Jul 03, 2008 | LG HBM-300 for VX9800 Wireless Headset
Health & Beauty Logo
630 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
