Question about Acomdata 500GB External Firewire HD 500 GB FireWire 400 Hard Drive
Clicking sound on Firewire 250GB
I wrote to Acomdata a month ago re: clicking sound on my 250GB Firewire
I sent in my Serial Number and contact info. NO RESPONSE.
The Mfg. Date was Nov 2005 and purchase date was mid 2006.
do I still have a valid warranty?! Most HD's have a 5 yr warranty, correct?
Who can help me with this b4 my warranty goes??
I never rec's a confirmation email from the official Website support.
does Acomdata have that much business or ineptitude?
Sincerely,
JP
Okay, I had this issue with my acomdata 500GB. today I decided to open up the drive to see if I could remove it and restore the data. after unscrewing all six screws (4 on the front and 2 small ones on the side, you'll need two different phillips, a large one and small one), I looked inside. first I registered the driver inside (it's a Western Digital) in case I needed to get it replaced. sure enough, it was still under warantee, even though the enclosure/driver kit is not (acomdata warantee runs out after a year for this model). but I noticed a slippage on the mangnetic copper film strip right above the USB port entry. it was slightly falling off the edge of the port. so I just fixed it, not thinking much of it, it just didn't "look" right. then I had a thought to plug it back in. driver now works again! I am about to recover my files and then test unplugging it to see if this repair "sticks".
Posted on Aug 20, 2009
What is the model number (and Windows 7 driver) for Acomdata external hard drive serial number AC07111300220
  • 1Connect the Acomdata external hard drive to your computer through the USB cable that came with the drive.
  • 2 Click the "Start" button on your computer screen and then click on the "Control Panel" tab.
  • Sponsored Links
  • 3 Click on the "System" button and then click on the "Automatic Updates" tab if you are running the classic view. If you are running the standard view, click on the "Performance and Maintenance" button and then click on the "System" tab.
  • Read more: http://www.ehow.com/how_6880582_troubleshoot-acomdata-external-hard-drive.html#ixzz345dOHa31
    got it by just searching and a whole buch of solution came
    May 05, 2014 | Acomdata Computers & Internet
    I lost My CD The Software
    there is no need of the driver for the external hard disk to work it will work wiyhout the drivers if you have the product code of the product please send it also
    May 26, 2010 | Acomdata 250GB External Firewire HD 250 GB...
    I just purchased a external hard drive case to use bc i was upgrading my hard drive to my laptop. now my new laptop has the bigger hard drive and my old hard drive that came out of my laptop reads 4...
    It sounds like your old laptop drive had 4 partitions on it.
    If that is the case and you want it to be only one partition then you'll have to back up anything you want to keep in those partitions and reformat the drive as one partition.
    You can reformat the drive using the Disk Management utility in Windows.
    Dec 05, 2009 | Acomdata 250GB External Firewire HD 250 GB...
    Drive not showing in toshiba satellite vista computer devices
    if your sure the device works, reassign some drive letters in computer administration to see if the drive is trying to use a drive letter being used by another drive.
    Aug 30, 2009 | Acomdata 250GB External Firewire HD 250 GB...
    Acomdata hard drive Model HD320FES-72
    Sounds like the drive has seized spindle... Not good news.
    Is it buzzing similar to any of these noises: http://datacent.com/hard_drive_sounds.php ?
    What you should do is remove the internal drive from the enclosure and connect it directly to the computer. If still buzzing then it's a real mechanical problem...
    Nov 02, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
    Purchased about two months ago. the external drive turns constatly making a grindin sound.
    You need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
    Jun 26, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
    HD will not start completely...
    CLICKING SOUND IS THE HARD DRIVE ACTUATOR ARM THAT IS FAULTY.DEAD HARD DRIVE. CAN YOU SEE THE DRIVE IN DIVICE MANAGER?? IF YOU DONT SEE IT THERE IT IS DEAD AND HAS NO HOPE.
    REPLASE THE DRIVE (SORRY)
    May 20, 2008 | Acomdata 250GB External Firewire HD 250 GB...
    No ned to check in that.
    The external hard drive can be fomatted by :
    Open the my computer, in the my computer or explorer window you should see the drive letter for the external drive.
    Right click on the drive you will get the popup menu.
    In that select the format option.
    But always use NTFS file formatting system.NTFS provides several advantages over FAT32, including support for larger ile sizes.
    Use the full format option.
    Wait for sometime, until the format is completed.
    Then you are good to go.
    Good Luck.
    Live, Love, Laugh.
    May 08, 2008 | Acomdata 250GB External Firewire HD 250 GB...
    Acomdata 500GB External Firewire HD 500 GB FireWire 400 Hard Drive Logo
    280 people viewed this question
    Top Acomdata Computers & Internet Experts
    Jerry Umali
    Joe Goldman
    Joe Goldman
    Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
