Question about Dell A215 Computer Speakers
Dell Speaker 215 problem
When moving furniture we plugged the router power into the speaker power input by mistake. Then plugged in the proper power. However, we get a loud hum/crackle and no sound - any ideas?
  • gordon houghton May 08, 2007
    Thanks ron700 - sadly I thought this might be the case - sounds as though I need new speakers. B****er!
    Problem Solver:
  • 14 Answers
Would suggest that when you plugged in the router power supply it supplied a HIGHER voltage and you have blown the speakers.
Posted on May 08, 2007
Sony STR-DN1010 with RCA output jack to Peavey PV-215 speaker input jack
is this a line level out put on the Sony? all the amp outputs on this unit use Banana Plugs, you will need an amp some where if it is. This speaker is not powered.
Jul 25, 2013 | Peavey PV-215 Dual 15 2-Way Speaker...
The speakers were working the I believe I accidentally deleted the speaker software they don't even so as a device on the computer and aren't working??
The speaker you have mentioned is no need a software to use in a computer try to check if you are connected properly in your computer. See to it that you plug in the power adopter of your speaker and the input of the speaker is connected to the output of the audio of your computer.
Jul 19, 2011 | Dell A215 Computer Speakers
Do not get sound when dell 215 speaker is powered on.
check to make sure that the wire to the computer is plugged into the right port, the mic. port is vary smiler. And make sure the sound on the computer is turned up.
Mar 01, 2011 | Dell A215 Computer Speakers
I just brought this computer to my house from my girl friends grandmas house speakers and all worked fine now i plugged everything in the the exact speakers that were on it are plugged into it and the...
Assuming something in the computer didn't mysteriously go bad during the move, there are two possibilities. First, make sure the signal cable from the speakers is plugged in to the right place. You may have plugged it into the microphone input or line input jack by mistake. Second, be sure the speakers have power. Most speaker systems require AC power, either from a plug-in adapter or a built-in supply that needs an AC connection. (Some newer systems come with USB-powered speakers that don't need an external adapter.)
A remote possibility is that in the move, the speakers got bumped enough to disturb connections on the circuit board inside. The amplifier chip in the speaker case gets hot (especially if the volume is turned way up), and the heat can degrade solder connections, and sometimes cracks form. The move may have caused connections that were iffy to go bad. But this isn't very likely.
You'll probably find it to be a very simple missed connection. Good luck, and thanks for using Fixya!
Oct 24, 2010 | Dell P4 2.8 GHz (DELLDIMREF1100) PC...
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
Speaker cable installation
1.  Check the orange multipin connector for bent or broken pins.
2.  Make you have the subwoofer plugged in to a live power outlet.
3.  Check the fuse on the circuit board inside the subwoofer.
4.  Measure the output of the subwoofer power transformer.  I think I remember it as being in the range of 12-24VAC.  Inspect the rectifier diodes for signs of overload.  measure the dc output of the diodes.  I think I remember 18VDC.
5.  Open the right speaker and verify the on/off switch is working.
6.  New Egg sells a multitude of similar speakers in the $40 to $80 range.
Apr 04, 2009 | Dell HK395 Computer Speakers
HOW DO I INSTALL THESE
please gibe me in detail what os you r using
and what sound driver have you installed
speaker may be 3.1, 4.1, 5.1 channel
Oct 12, 2008 | Dell A215 Computer Speakers
Where do I plug up the altec Lansing acs41 speakers to a new Dell computer
try to plug it at the back of the computer you will see there the outlet for the speaker , it has 3 color, pink for the mic, green for the speaker , hook up the green input cable from your altec lansing to the green outlet of the PC then plug the speaker to the power and there you go h\you have your speaker running
Jul 22, 2008 | Computers & Internet
Speakers won't work
Hi, you may want to try plugging the input line of the Dell speaker to the other jacks. Normally green is for speaker, pink - microphone and blue is for line-in and all are normally at the back of the computer. Sometimes, the back are deactivated if there are jacks in the front., so you may to try plugging it in the front if they are present. Assuming the speakers light/power up, if you want to check if they are working is by touching with your finder the input plug which should produce a humming sound. Also worth to check the drivers of your sound card. Hope this works for you. Regards.
Apr 14, 2007 | Dell A525 Computer Speakers
Speakers produce effect noise but no music...
Check to make sure you have not lowered volume or muted any sounds--- go to speaker icon in tray, double click and check to make sure all sounds are on! Hope this helps.
Feb 13, 2007 | Dell A215 Computer Speakers
Dell A215 Computer Speakers Logo
113 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
