Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice Maker Troubles
Whirlpool Refrig. Ice Maker #4317943 makes ice , seems like it maybe getting to full, you have to unplug , take ice out & plug back in, it will make ice for awhile & stop again.
  • 242 Answers
Hello Mcelroy , I can help , your tray is overfilling and freezing the fingers/rake in ice so they can not turn the cubes out , this is caused by a leaking water inlet valve not shutting down on time or your ice maker module is calling for too much water on a harvest.
The best way to repair this issue would be to replace both the ice maker and the inlet valve which is located in the lower rear where your water line ties in.
All you have to do is order the ice maker kit for your model and it will include both parts you need the ice maker and the valve. These two items complete the entire ice making process so you should not have any other problems with your ice maker for a long time depending on water quality and wear and tear. If you have any other questions please let me know and tell me how it turns out if you have the chance. Good luck. Phil
Posted on Jan 01, 2009
    Sergeant:
  • 311 Answers
If you can stop ice production by lifting up ice maker bail.great!then just bend that same metal bail down more so will hit the ice when enough is made.God bless,tom
Ice making parts need to be rescrewed into mechanism
Refrigerator Repair - Replacing the Ice Maker Shut-Off Arm ...
? 8:09
https://www.youtube.com/watch?v=nTG9R4arsQE
Mar 19, 2013 - Uploaded by PartSelect
SourceCode=15 Click here for more information on this part, installation in... ... Refrigerator Repair ...
Replacing the Icemaker (Whirlpool Part# 4317943) - YouTube
? 5:51
https://www.youtube.com/watch?v=ECdu8xqf0Ns
Apr 5, 2011 - Uploaded by PartSelect
Refrigerator Repair- Replacing the Icemaker (Whirlpool Part# 4317943) ..... snap the circuit board cover onto ...
How to Install a Refrigerator Ice Maker Kit - YouTube
? 2:49
https://www.youtube.com/watch?v=zR3Jt7k39Zs
Jun 26, 2015 - Uploaded by searspartsdirect
Leave the mounting screw loose. Install the mounting screws into the side freezer wall leaving enough ...
Jan 01, 2016 | LG Refrigerators
I have a whirlpool model ED25PWXBN00 refrig and the ice maker is making ice but the part that holds and dispenses the ice has broken and no longer dispenses ice. what part do i need?
That depends if the ice maker continues to fill with water or just sits there with the ice slots empty. Sometimes it is the dual water control valve=> 4318046 Water Control Valve
and sometimes the ice maker itself. Does not hurt to have an extra part of each if you are a ice user like myself. If ice slots are empty fill with tap water and allow to freeze. If the ice drops and slots do not refill with water then replace the dual water control valve. 4317943 Ice Maker Assembly.
Oct 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is not working
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker won't work
Most ice makers have some sort of on/off lever to shut off when full, check this for any left over packing material or tape that could holding it making it thing it is full instead of filling to make ice.
Jun 18, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I AM HAVING A PROBLEM WITH MY ICE MAKER FOR THE WHIRLPOOL MODEL ED5FHEXMSI0. THE PROBLEM I'M HAVING IS WHEN I PUSH DOWN THE BUTTON ON THE ON POSITION,I GET A NOISE DURING THE ICE MAKING PROCESS.NOW I 'M...
it sound like the the module on ice maker is broken on etheir case is better to repl the ice maker just remove the 3 screws on ice maker 2 on top 1 on bottom unplug wire harness install the new one same way part number is 4317943 this is a ice maker for all whirlpools one fits all that is if you are getting wtr ok let me know
Oct 15, 2008 | Whirlpool Refrigerators
Ice Maker Won't Drop Ice
you have a problem in the module of the ice maker if it is new take it back for a new one
May 02, 2008 | Refrigerators
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
93 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
