Question about Whirlpool GU2400XTP Built-in Dishwasher
Quiet Partner II will not start
Normal cycle green light continually blinks and the washer will not start.
  • hayden_env Jan 02, 2009
    The normal cycle and cancel/drain lights continually blink and the dishwasher will not start. We shut off the breaker/power to the unit for over an hour and then turned the breaker/power back on. This did not help the situation.
    Genius:
  • 1,199 Answers
Make sure water float inside of door is not stuck in the up position!
Posted on Jan 02, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, possibilities are:
  1. door latch defective (unlikely);
  2. door lock sensor/switch (likely);
  3. open heater element (a possibility);
  4. faulty thermal cut-off (a possibility);
  5. systems glitch, perform a reset:
  • press heated dry, normal, heated dry, normal and then cancel;
  • wait until 2 minute cycle is done;
  • open and close the door and make sure it is closed.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 01, 2009
    Genius:
  • 3,422 Answers
If your dishwasher doesn't work at all, check these:
Power from the house Isthere power getting to the dishwasher? This can be difficult to test,because dishwashers are usually wired directly to an electricalcircuit, rather than plugged into the wall. But at least check for ablown fuse or a tripped circuit breaker.
Door switch Thedoor switch is important because, if it's defective, the dishwasherwon't work at all. To reach it, you need to remove the control panelcover, or sometimes the interior liner of the door. If it's defective,you need to completely replace it.
Wiring Oftenthe main wiring connection from the house, at the dishwasher, burns andbreaks the connection. If that's the problem, the wires must berepaired/replaced as necessary. If that's not the problem, check thewiring to the door switch, the wiring between the door and the lowerpart of the dishwasher, and the wiring to the timer. Repair any broken,burned, brittle, or defective wiring, using the proper appliance-gradewire and connectors.
Timer or selector switch Althoughit's uncommon, the timer or the selector switch may be defective. Ifso, you need to replace the defective part, because neither of thesecan be repaired.
    President:
  • 2,110 Answers
Press:
heated dry
normal
heated dry
normal
then cancel..... wait until 2 minute cycle is done. open and close the door and make sure it is closed.
Then run another cycle. saw this on another post and it worked for me. They said that if it did not reset then either the latch has a bad connection or the heater for the water is bad.. it must register that the door is closed in order to actually start the heater for the water. I hope this helps you as well as it helped me.
    Genius:
  • 1,550 Answers
Reset
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Lock light stays on my whirlpool quiet partner II
If pushing and holding the lock button till the light goes out doesn't work, you likely have a problem on the circuit board.
May 24, 2014 | Dishwashers
Whirpool quiet partner 3 gold. panel lights work and say it is wasing but doesn't start
The timing circuit may be defective and the circuit board needs replacing. Have an authorized serviceman do a continuity test on the board and have it rest to factory specs.
Feb 27, 2014 | Dishwashers
I have a Whirlpool Quiet Partner II dishwasher and it is stuck in the clean mode the light continuous blinks
THat means that something is wrong with the water temp. It is either not hot enough when it fills or the heating element that increases the temp it bad. To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Feb 22, 2013 | Dishwashers
How do I reset blinking lights?
Switch the breaker off for a minute.....
Aug 26, 2012 | Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner Doesn't finish cycle
FIX YA IS A JOKE I WOULD LIKE TO BURY THE ************** WHO CREATED IT!
Jul 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Apr 09, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
