Question about 791XV The 791XV is a 2-way Security and Remote Start system. Th
Viper remote 771xv works, but gives three steady tones at regular intervals after using.
  • 26 Answers
That means that your remote is not receiving a signal from the remote starter. That's a two-way unit designed to transmit(tx) and receive(rx) signals to and from the antenna or brain. If it doesn't do either one, the remote will give you three triple beeps.
Posted on Jan 16, 2009
I have a viper 5900 car alarm with the 7701 vpx remote and the lock and unlock are reversed. How do I fix this
according to Viper tech support (I emailed them your question):
Thank you for contacting Directed support!
You may need to reprogram the remote to your phone. Please use the following instructions to reprogram the remote:
To program the remote to your system please do the following:
1) open the driver door
2) turn the key to the "on" or "run" position
3) locate the valet switch (small black button under driver side of dash) and press once, release, then press again and hold
4) after the siren chirps one time press the lock button on the remote
5) the alarm will give you a unique confirmation tone
6) turn the key off (the same unique tone will be heard again)
Warm regards,
Nigel McGee I Customer Service Rep.
Viper Support
Apr 28, 2016 | Viper Vehicle Parts & Accessories
My remote works but it no longer gives me confirmation. Even though it still locks/unlocks/& starts the car, instead of the confirmation tone, a long error sound comes out w/flashing red lights each...
Unplug the antenna on the windshield, let it sit for a couple minutes. Then try plugging it back in. If that doesnt work you can all them direct at 1-800-876-0800
Jan 12, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hi, when I try to use my starter option on my viper 5701 I get an error tone. when i turn off the ignition or try to use the starter option I get seven flashes on the parking lights. what does it mean and...
Seven flashes is the neutral safety switch. Check under the dash for the toggle switch labeled "on/off" and flip the switch to on. If this unit was just installed and you have always received the error tone then, the thin black/white wire must be connected to ground.
Jan 11, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Mts mode for preset manual trans auto start function enable,does not allow car to start, instead the park light blinks seven times and give an error tone ... Thank you
There is a sequence necessary to set the Viper every time you exit the vehicle: park the vehicle, put in neutral, place foot on brake, set parking brake,remove foot from brake, remote start vehicle with remote, remove key (vehicle should remain running), exit vehicle and close door, arm the alarm with remote (vehicle should shut down). The system is now set for MTS remote start. Test the system by remote starting the vehicle now (it should remote start at this point). If you open any door after the MTS remote start has been set, you will have to do the programming sequence again.This is a safety feature because something may have changed, i.e. parking brake released when the door was opened. You have to do this sequence each time you park the vehicle if you intend to use the remote start feature.
If this does not work, there may be an issue with the installation, i.e., the door trigger connection. Using dome supervision as a door trigger won't work because during the arming portion of the above mention programming sequence(when the vehicle shuts down), the interior lights will illuminate and the Viper will read it as a door opening. So, actual door trigger wires must be used.
Oct 23, 2010 | 5900 SST 2-Way Security System / Remote...
Viper rpn471t light steady
You have to have a door open on the vehicle then press lock-unlock-lock within one second and the alarm will come out of valet mode, which it's in when the light is lit steady.
May 06, 2010 | Remote Start System
I bouth viper remote starter system with keyless , which bypass i ll need to instal that on pontiac g6 2006
Dont mess around with this type alarm system ,i wouldnt evan consider installing anything like this ,look at the amount of questions from people with cars with this add on system that goes wrong at regular intervals .Save your hard earned cash
Dec 19, 2009 | 2006 Pontiac G6
Viper 771xv remote start problem
the led should blink a code that tells you why it shut down or failed to start
Jul 05, 2009 | Vehicle Parts & Accessories
2003 chevy trailblazer. alarm problem 771xv
Jan 20, 2009 | Vehicle Parts & Accessories
791XV The  791XV is a 2-way Security and Remote Start system. Th Logo
440 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
