Question about Amana 5939 Grill
Troubleshooting amana gas grill
I am having a problem with an amana gas grill that we bought in august and have only used a few times grilling steaks. we have changed gas tanks thinking that they were sold empty because the flame only stays low, there is no heat to cook. we replaced the regulator worked when we tested it then the next day tried to cook on it and it is doing the same thing.. What to do next? frustrating..
  • 2 more comments
  • kimfcu Feb 06, 2009
    I get a desent flame on 1st and 2nd burner. No gas output on 3rd and 4th burner Help Jeff
  • Anonymous May 05, 2009
    burner to the left has a good flame the other three are weak
  • subluxatr020 May 14, 2009
    lo flame unresponsive to valve changes changed reg and tanks multiple times
  • Anonymous May 19, 2009
    Gas Grill Middle burner dosen't light
From a tag that came with the grill -
"To ensure proper gas flow, all of the burner control valves MUST be off before opening the LP cas cylinder valve.
When turning on the LP gas cylinder valve, make sure to open the valve SLOWLY two complete turns to ensure proper gas flow.
All LP tanks now come equipped with a leak detection device internal to the tank, when gas is allowed to escape rapidly it will restrict the gas supply to the appliance. Opening the valve rapidly may simulate a gas leak, causing the safety device to activate, restricting gas flow and causing low flames or poor ignition.
Opening the valve slowly will insure this safety feature is not falsely triggered."
I would guess you triggered the tank failsafe inadvertently.
Posted on Jan 28, 2009
How do I cook ribeye steak
on the grill! get yourself nice dryrub at your local food store and throw it the grill. i dont let my temp get higher then 300 i cook them low and slow!
Dec 08, 2014 | Grilling
My7 Baby q doesnt get hot enought to sear steaks
Their are several things that can cause this problem:
1. The burner(s) need to be removed and thoroughly cleaned.
2, Low amount of gas in the tank.
3. The grill's gas regulator is partially seized.
The first two are easy for you to solve, The third one is to if you do the following:
Turn the gas tank valve OFF. If you're using a 20lb LP Gas grill tank, disconnect the hose from the tank and wait 5 minutes, If you're using a small 1 lb cylinder, turn it OFF and remove it from the grill. after 5 minutes, reconnect the hose to the tank or reinsert the small cylinder and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open light the burner(s) and turn it to the highest setting. Did the burner light and does the flame height look correct? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly.
If the above didn't solve the problem, you will need to replace the grill's hose/regulator assembly (if you're using a 20Lb LP Grill Tank). Which you can find at any home center or hardware store that sells gas grills and accessories. If you're using the smaller insert-able tank, you will need to replace the tank's hookup and regulator mechanism.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Jun 03, 2011 | Weber Baby Q Grill
What # should i use for 1in. t-bone steak mod. ggr50b
To first sear the steak on both sides, turn it to it's highest setting. After both sides have seared for about 3-5 minutes per side, depending on the thickness. Then turn the temp down to medium and continue to grill to the way you like it turning it once more. Never use a fork to turn the meat. It pierces it and allows those wonderful juices to drain out. Use tongs instead. Once it's cooked to your liking, take it Off the grill and allow it to rest 3-5 minutes. That way, when you cut into it, most of those wonderful juices will remain in the meat.
Hope this helped you and enjoy your steak! Happy grilling!
May 05, 2011 | George Foreman GGR50B Grill
Crossover channel for burners is broken where can i get replacement
i have a jenn air grill, i have bought new burners & heat plates, i still cant get it hot enough to cook a steak, i have replaced the fuel tank& regulator, what gives? any suggestions
Mar 28, 2010 | Brinkmann 810-8410-S Stainless Steel...
What are some close cooking times for infrared grills
In only three minutes, the grill hit 1600° F, nearly three times hotter than a standard gas grill. Steak-Five minutes later, it was done to medium-rare perfection.
Chicken Breast After 10 minutes — half the time it normally takes, it was done. The grill uses the same radiation as similar to a microwave if that helps with determining other times. if this helped please rate me and let me know...good luck!!
Jul 18, 2009 | Kenmore 774 sq. in. Cooking Area Gas Grill...
What is the reason why I can't use lava rocks and a grate in any propane gas grill?
who said you cant?????????? use whatever the hell you want to....... ceramic or lava.... just make sure you keep the flame down to about medium and give those steaks a good two days to marinade and call me when your gonna heve em ready!!!!!!!!!!!! need a good marinade recipe??? garthayling@hotmail.com shoot me an email and i;ll hook you up with the best ive tried.... good luck
Jul 15, 2009 | Grilling
Regulator doesn't allow gas to flow to grill . Grill cannot heat hot enough to grill steaks. Gas flows too slowly.
Shut off the gas at the tank and disconnect everything.
Unscrew the plastic cap on the regulator. Inside is a flat screw top that has a single slot or an X-shaped slot. This is the pressure adjustment. It controls the diaphragm that regulates gas flow.
Note where it's set. Use a Sharpie to mark the adjuster on its edge (place a dot there), and make a corresponding mark on the threads next to it.
Next, use a large screwdriver or a coin to spin the adjuster counterclockwise three or four times. Pay attention to the number of turns. Now, screw it back in (clockwise) the exact same number of turns, stopping at the index mark you made.
Next, turn the adjuster two turns clockwise, followed by two turns counterclockwise. The idea is to end up where it was originally set. This action unsticks the regulator's valve seat. Done.
Put the cap back on, hook it all up, open the tank valve, and make fire.
Oongawa!
-Peegoo
Jun 23, 2009 | Thermos Stainless Steel Gas Grill
Gas grill not hot enough
Always turn your tank on first. Then the burners.
Try this, turn the burners on for a minute and then off with the regulator and hose off the tank, then hook it back up and very slowly open the tank. Then fire off the burners.
If this doesn't work, try replacing the hose/regulator.
Mar 22, 2009 | Kenmore 632 sq. in. 16324
Unsatisfactory grilling
You need a bigger, more powerful grill. It sounds like the one you have cannot keep up with the amount of food you want to cook. Other than making sure any controls are set on maximum, there's not much you can do about this. Return the unit for a refund.
Apr 11, 2007 | DeLonghi Perfecto BG24 Indoor Grill
Amana 5939 Grill Logo
1,412 people viewed this question
Top Amana Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you an Amana Grilling Expert? Answer questions, earn points and help others
