Question about Hotpoint RGA520 Gas Kitchen Range
Pilot lite for the oven need it located
Pilot lite located for the oven
  • 306 Answers
If you remove the bottom panel inside the oven you will see pilot and burner that heats the oven.
Posted on Jan 01, 2009
Need to turn gas pilot on
Stove in ? has electronic pilot so there is nothing to turn on
top burners should have spark and oven has a glow
if the burners not lite do you here a clicking sound no clicking spark box is bad
oven not lite need glow
price of glow $40 price of spark box $60
Nov 02, 2014 | Hotpoint Kitchen Ranges
My oven pilot light will not stay on
you may need to replace thermocouple and re-try it....good luck.
Nov 06, 2012 | Southbend S560DD (Gas) Oven
Piolt lites but will not stay lit for hotpoint RGB524pph2wh
If you are referring to the oven pilot lite, you will need to replace the "Oven Pilot with Thermocouple". Here is a link to the part you need.
Sep 29, 2011 | Hotpoint RGB745 Gas Kitchen Range
MY SUBURBAN OVEN PILOT LITES, BUT WHEN i RELEASE KNOB PILOT GOES OUT AND OVEN WONT LITE. i REPLACED SAFETY VALVE BUT STILL SAME PROBLEM.
the polit light lights but when you let the nob go for the oven burner to come on the polit light goes out
Sep 22, 2011 | Ovens
How do I lite the oven pilot.
Sorry to read about your problem, I hope this helps you out.
most new oven's, gas or electric you do not lite....you may have a defective unit....
if its real old, you oven knob should say pilot...if not you have a newer oven...
then you have a defective pilot system
Dec 25, 2010 | Ovens
My gas oven will not start up to bake
The most common problem,
1. if your oven uses a pilot light..it blew out
2. if it does use a pilot lite, you have electronic pilot..if so the glow plug is burned out...
If your top plates go click click click to lite, you have electronic pilots
Dec 19, 2010 | Kitchen Ranges
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
Need to know how to light pilot lite on hi point gas range. 1993 yr
The pilot is located in the bottom of the stove, you will have to open the bottom drawer if it has one or you have to remove the bottom cover inside the oven, either one you will see the pilot and you just need to re-lit it with a lighter, it will light instantly once the flame is near the pilot.
Feb 17, 2010 | Kitchen Ranges
When Oven turns off so does oven pilot
Hi there, it is possible of the pilot being too close, but usually does not have that effect, unless the pilot is too small. But if you replaced the pilot, it should be clean, so next I would look at the gas pressure, if this is too low, the flame won't have proper burning speed, and strength, and could get drawn out. The control valve may be of the type that has a regulator built in, you may need someone skilled at gas pressure measuring, to do this, your gas supplier, appliance professional, plumber, should be able to do this.
Let us know, and thank you.
Jan 29, 2009 | Garland GPD-60-2 Gas Double Oven
Hotpoint RGA520 Gas Kitchen Range Logo
197 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
