Question about Coby DVD-755 System
Subwoofer feedback, and no sound
Hi, got a new theatre system for Xmas. Its a Coby (CS-P63), with a DVD-755, the TV is a magnasonic. The dvd player plays music cd's, the FL/FR work as they should for the music ( I used these plugs to check all the speakers to make sure they worked), and they do, so they are wired right. However, the sub has a low hum, and when I put in a dvd I only get sound from the TV. I think there is some sound from the centre speaker, but no dialogue. i triple checked all the wiring for the system, and tried all the options in the manual, but have gotten no results. I tried to contact the company but of course got machine after machine and no humans. I sent off an email but expect no answer. I also tried to adjust the audio on the setup in the dvd player but only have the options of changing the room type, and that's it. the volume on the Sub doesn't seem to give any results either. What am I doing wrong?
  • tmarcoux Jan 01, 2009
    Why? And its probably not gonna happen, dad never keeps receipts. Any other ideas?
My sub does the same thing. I hooked it, (my sub) up as the center and it worked fine thinking that it was the center speaker. Changed to different wires as well. It has to be a configuration issue that is somewhere telling the sub not to work within its proper capacity but I have checked everywhere within the menus on mine as well to no avail.
Posted on Jan 04, 2012
    Genius:
  • 1,175 Answers
Hi
Take it back and get another if you can.
Posted on Jan 01, 2009
  • Scott Frye
    Scott Frye Jan 01, 2009
    Try a different set of stereo cables from the DVD player..Hum says there's a ground wire /shield wire broken or not connected.
COBY cs-p63 ,how to connect to a 42 in. tv
3.5mm is stereo sound, which means 2 speakers. so no there isn't a cable, u could get a 3.5mm to AUX cable, but that would only play sound out of the front 2 speakers and the subwoofer. otherwise you would need a device that supports 5.1
Oct 21, 2012 | Coby 5.1 Channel DVD Player with Home...
How do i hookup to tv
how do i hook up my dvd 755 with suround sound
Feb 16, 2010 | Coby DVD-755 System
Only geting sound from two speakers with my 5.1 channel system
Make sure the source program is 5.1, change receiver settings to emulate 5.1 if source is not 5.1
Jul 26, 2009 | Coby 5.1 Channel DVD Player with Home...
I have a coby dvd player which is connected to my home theatre sound system. However, i canot increase the volume to a satisfatory level past #20. the theatre sound system is at max volume.
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, there is no way to increase the output of the Coby dvd player within the player itself. It may be that the player isn't outputting very well through the audio coaxial output which i presume your using. If this is the case, there is no fix for that type of issue. You would want to replace the player.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 16, 2009 | Coby DVD-224 DVD Player
Unlock the coby DVD-755 to free region use
I believe this works - I've yet to try it myself! Coby DVD-755 1 user region code/hacks August 13, 2007 Post region code/hack comment Region code hack posted by Peter, August 13 2007: DVD -755 from Walmart home theatre for $79.00 1-Press ?Setup? 2-Press Vol +, Vol-, Vol +, Vol -, 3-Number shows up 4-Change the region code by using RIGHT arrow. 5=Press ?Setup? to exit. Succesfuly tested bt Peter F.
Jun 29, 2008 | Coby DVD-755 System
How to restore factory settings for Coby 755 DVD Player
Ok I'm going to walk you through this...
Turn the DVD player on... give it a second to load up
Now Press Setup.. now navigate down 5 times Press Enter
Navigate down once Press Enter... Or it might just be a Press enter I'm reading from the manual. Click here for the Manual
That is the way to get to the factory default button in the setup.. If your having trouble doing that try using the manual to see where to go to get back to the NTSC settings
May 03, 2008 | Coby DVD-755 System
Coby dvd 755 home theatre system hook to directv
The composite output (red, white and yellow) on the directv receiver should connect to the audio in (red and white) on the coby ht system. Then you have to select the correct input on the coby til you here the audio from the DTV receiver
Feb 10, 2008 | Coby DVD-755 System
COBY cs-p63 ,how to connect to a computer
with this system it comes with connector cables, on one end is 3.5mm to go into your computer and the other end is rca jacks that go into the subwoofer, all the speakers go to the subwoofer. your computer must have all 5 ports to get true surround sound, if not, just hookup the ones for the FL FR and run RCA split from that to the speaker output on your computer.
Feb 09, 2008 | Coby 5.1 Channel DVD Player with Home...
Tv sound on home theater kit
Hi Every one.
Had same problem with my HDMI connection on my sony bravia and sony theatre system, resolved by conecting a scart lead from the theatre system to one of the free scart sockets on the back of the TV, leave your HDMI connection in place as the DVD signal comes from this,
hope this helps!
Dec 20, 2007 | Audio Players & Recorders
Sound from tv
The DVD-755 does not have any input source, so... not possible, sorry :-(
Dec 01, 2007 | Coby DVD-755 System
Coby DVD-755 System Logo
353 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
