Question about Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300
Ilectrical problem i used it for 10 minutes and it stopped working at all.does anyone know how to replace the fuse?
I have a similar problem with my unit. found out that Homedics only does repairs under warranty. After that you are on your own. I did remove my covers from unit and located the power supply. Their is a fuse there to replace near edge of board. Mine was good and I checked voltages through secondary of transformer. At this point without a schematic it will be painful to trouble shoot. Looked for a brand name on power supply with hopes of buying one from a supply house. no such information and it looks like an OEM product for this use only. It is a bust and I will not buy another Homedics product because they will not service unit past warranty Expendable Electronics! Not good for anyone!
Posted on Apr 27, 2010
If I only used it for 10 min. and it stopped working? I would quickly throw it back in the box and find a store that sells them and demand a replacement. Or just buy the same exact model and then return the broken one to the store with the same reciept.
Posted on Feb 20, 2009
SOURCE:
Map,vanity,glove box lights
locate the fuse that provides power for these lights and clean the prongs of the fuse using a knife ,razor blade or sandpaper.If this does not help,I would find out from the dealer if they list a module for these lights and if so replace it.hope this is helpful to you,good luck.
Mar 30, 2014 | Vehicle Parts & Accessories
How to fix Polycom soundpoint IP 335 with surge damage
The IP 335 is an entry level phone so it is doubtful that there would be anything like a fuse in it. From what you've described here I would say the phone is fried. Moving forward I would recommend to always keep your important electronics on a good quality surge suppressor and/or a UPS. Good luck.
Jun 26, 2012 | Polycom SoundPoint IP 335 IP Phone
Just one day stopped working
mine did this, too. There's some small component inside I've traced the problem to but I don't know what exactly the component is nor where to get a replacement. Unless you can crack yours open and replace the component you might be out of luck.
Dec 13, 2009 | Oster 4715 10-Cup Rice Cooker
The lighter socket was working fine until I plugged in a ran a mini ice defroster and it stopped working after 10 minutes and has not worked since that time
check the fuse for the socket. I bet it just needs to be replaced. To keep using your defroster you may want to check its power (A) and install a corresponding fuse, but consult the car's manual or ask an owner of such vehicle what is the max safe value of the fuse. Past it and the wires will burn!
Nov 06, 2009 | 1996 Honda Odyssey
My macerator turns off and stops working for 10 - 15 minutes
the macerator is over heating.check the maintenance opening and clean it ,but you may need a more powerful macerator,some are made only for flushing systems (as in toilets) a pro-longed use may be making it overheat.. good luck
Jul 02, 2009 | Saniflo & Saniplus& Macerator Pump
Dometic RM2862 will not come on at all, no blown fuses or tripped breaker. no lights come on either. Any thoughts?
I have the same problem Have replaced the power Modular still Refrig light or anything styill doesn't work. Anyone have any suggestions?
Jun 27, 2009 | Dometic RM2852 Refrigerator
Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300 Logo
1,143 people viewed this question
Top Homedics Health & Beauty Experts
Lynnette Kinsman
Arturs Kalnins
Arturs Kalnins
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
