Question about Microsoft Xbox 360 Console
Black and white picture
When we plug our xbox into our JVC tv, it appears only in black and white, all the other tvs in the household are in color so we don't think it's the xbox... any suggestions?
  • Anonymous Dec 24, 2008
    my xbox has the same problem tv is brand new
  • wat1999 Dec 26, 2008
    We also have a JVC colour TV but it doesn't allow xbox 360 premium games or DVD to display in colour, b/w only.
    Changing PAL display from 60 to 50 doesn't work either.
    All help greatly appreciated.
The solution might be simple. If you´ve only tried one AV input on your TV, you should try one the others, i.e. AV1, AV2 or AV3.
Posted on May 27, 2007
  • 34 Answers
Do u have your 360 display settings at 60hz if so the tv might not be compatiable with a 60hz signel go to display setting and drop back to 50 hz and colour may show it self but remember some games wont play in 50hz if this is the case try find a ntsc to pal converter
Posted on May 26, 2007
  • STUART LITTLE
    STUART LITTLE May 26, 2007
    sorry forgot to ask is it a 360 or a normal xbox
SOURCE:
I have the new black xbox. We just changed tvs to a new plasma samsung and when i plug all of the cords in and turn on the xbox it works, except that the colors are bloack and white. It gives a good...
make sure that if you have the hd cords plugged in the switch is on hdtv and if the regular cords are plugged in the switch on the a/v cords says tv. make sure the red cord is in the correct socket. if you are using hdmi cord then it needs replacing. also you may find some sucess by changing the output in the xbox settings.
Jul 31, 2011 | Microsoft Xbox 360 Console
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Mar 05, 2011 | Philips DVP3560 DVD Player
My xbox appeared black & white in my tv monitor
There might be a problem with the jack inserts on the T.V. have you tried wiggling the jacks while there plugging in to the T.V. and also make sure the same cord is securely connected in the back of the console.
Apr 18, 2009 | Microsoft Xbox Console
Dont know what color to stick where
X-box can be hooked up to component video. This is for better picture quality. Not all tvs have this option. Most newer tvs do. It uses green, red, blue. Those will give you the video. Then a red and a white give you the audio. Just match up the colors.
Apr 08, 2009 | Sony KP-61HS10 61" Rear Projection...
Xbox original not showing color screen
Put the xbox on another tv. If it is in color then, the AV inputs may be bad. If that is the case, you may need to buy an AV-UHF/VHF converter, or plug them into a VCR.
Aug 17, 2008 | Microsoft Xbox Console
Color problem
Please fine tune those B/W channels to obtain color picture. If TV is more then 4 - 5 years old, it needs resoldering in tuning area or might need replacement of IF block.
Aug 01, 2008 | JVC AV-21meu 21" TV
Black and White Only
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color.
FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
Jan 30, 2008 | Microsoft Xbox Console
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
No color on Sony TV, all other tvs are great
check the av cables in back of your tv and also check the wires connected up to the xbox 60 it's self
Sep 01, 2007 | Microsoft Xbox 360 Console
Black and white images
I had the same problem with my Playstion2. I found that the playstion was givin an NTSC video output but the TV was only for PAL. try it on a TV that is PAL if your gamestation is PAL or on an NTSC tv if its NTSC. Does this help?
May 26, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
369 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
