Lexar X6650 AllInOne InkJet Printer Logo
Nancy Overton Posted on Oct 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a x6650 lexmark printer and I lost the disk to install it in my computer, where can I get another one
Where can I get a new disc. Lost mine
Anonymous
Level 2:
  • Expert 257 Answers
  • Posted on Oct 17, 2012
Anonymous
Expert
Level 2:
Answers
257
Questions
0
Helped
210595
Points
671
You have to download the drivers and software from Lexmark.
Here's the link to the download. (best to copy and paste)
I'm assuming you're using Windows 7. The file you need is dated 6/21/11. there are two on the list - one for 32 bit and one for 64 bit Windows7. If you click on your PC's START button, then right click on "COMPUTER" then click on "PROPERTIES", you will see either 32 bit or 64 bit operating system listed in the popup window.
http://support.lexmark.com/index?page=driversdownloads&linkSelected=node2%5Esubnode2&locale=EN&userlocale=EN_US
2helpful
2answers
Lost installation disk for lexmark prevail pro705
Please visit the Lexmark website to download and install the Lexmark Prevail Pro705 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
How do connect a x6650
Simply run the X6650 installation software on your computer. The software will also show you detailed instructions on how to setup the printer itself. If you don't have the installation disc, you can download and install the X6650 printer driver from the Lexmark website.
Please visit the Lexmark website to download and install the Lexmark X6650 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Do i need software like ocr so that the lexmark x6650 scanner can work
If you are scanning documents for editing or saving them as PDF, you will need to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If your scanner was working before, it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document again to verify that the problem is fixed.
I'm trying to scan and it says missing ocr for my lexmark x6650 lost my cd for lexmark
The Lexmark OCR scan software is only available on the installation cd that came with your printer. It is not available in the Lexmark.com website as part of the downloadable driver.You may contact Lexmark technical support for additional assistance.
2helpful
2answers
2answers
Lost installation disk for Lexmark X1240 all-in-one printer
i cannot find my disc for my 1300 lexmark printer. how can i down load it so that i may re- set up my printer?
2helpful
3answers
How to install printer without cd installer printer is Z1300
I LOST MY DISK TO INSTALL MY LEXMARK Z1300 PRINTER WHAT CAN I DO
Top Lexar Office Equipment & Supplies Experts
k24674
Are you a Lexar Office Equipment and Supply Expert? Answer questions, earn points and help others
