I inherited this tv, works fine however I want to disable the guide plus from coming on when I turn on the television. I do not have the manual and have made some attempts to navigate the menu on my own with no success
Comments:
Jan 06, 2009
- Thansk so much you don't know the grief you save me everytime I turn on that set :-)
-   want to disable guide plus-   dmayfield982
Mar 07, 2009
-   I inherited this tv, works fine however I want to disable the guide plus from coming on when I turn on the television. I do not have the manual and have made some attempts to navigate the menu on my own with no success-   Guest
With the remote, press the Guide button. This should bring up the Guide Plus+ screen. Press the right arrow to move the cursor all the way to set up and it will ask, "What would you like to do?" Arrow down to "Review Options" and press OK.
The first question is, "Guide Plus+ System Auto Display? On / Off"
Arrow down to Off and press OK.
I had a GE model with Guide Plus. Also, a universal remote which had no Guide button. What worked for me was using the buttons on the TV. Press Vol up button to 'scroll' right. When 'Setup' is highlighted, use 'Menu' button to select. Press Channel down to highlight "Setup' (again) and press 'menu' to select. Follow that pattern through each selection, setting zip code to 00000. When I finished, I turned the TV off then back on, and the GuidePlus has not appeared since.
can't get all the channels and they are programmed into the tv, and when i go to certain channels...
(More)
can't get all the channels and they are programmed into the tv, and when i go to certain channels there is about 6 of them that show the same program. how do i fix
Were can I get PN 1544445A for my GE Television Model #32GT740 Serial #126331503 Price and...
(More)
Were can I get PN 1544445A for my GE Television Model #32GT740 Serial #126331503 Price and delivery.Thanks
the picture and sound were blinking on and off, but the channel and cc info stayed on...now it won't...
(More)
the picture and sound were blinking on and off, but the channel and cc info stayed on...now it won't turn on at all
