Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice despenser in side by side door, kenmore does not work
Our kenmore side by side ice despensor does not work.. It makes ice, we just have to open the door to get it out.. When you press on the despensor it doesn not make any sound..Our power was out for several days after Ike, but I can't remember if it worked before or not.water despensor works fine, just can't get the ice one to work Help.
  • cpzdriver2 Jan 04, 2009
    I have the same problem, also stopped working after a power outage. Any ideas?
Pull the grill cover off near the floor and look to see if any of the wires have been cut. I found that the grill cover wore on the wires controlling the door functions. First the crushed ice function went, then the water dispenser went. I had splice the wires back together and am leaving the grill cover off. No problems since.
Posted on Jan 07, 2009
HAVE A KENMORE FRIDGE M.#106.74253400 WATER DESPENSOR STOPPED WORKING AN CAN HEAR IT HUMMING AN ALSO THE ICE MAKER WORKS SO I NO ITS GETTING WATER? THANKS
my kenmore did the same thing, It had a duel water solenoid on it and one that let water into the door water dispenser went bad. also my ice cube started to get smaller, the rubber in the other side of the water solenoid was dry rotting and eventually ruined the ice maker. I replaced the duel solenoid and ice maker and had no more problems.The solenoid is on the back of the fridge, it is what the main water supply connects to.
Dec 31, 2011 | Refrigerators
The door ice despenser is not working. It makes
Make sure that the bucket is pushed in all the way. If the motor is running the screw should be turning. I would also take the bucket out and try to turn the auger by hand to make sure it is turning free.
Please rate solution if helpful. Thanks
Aug 19, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
No Ice is being made. Water is being despensed at the door but it seems that no water is going to the ice maker. Have good water flow to the pump.
Is the ice maker turned on?  The on/off switch is located on the top right side of the freezer compartment.  The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full.  Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
May 30, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Refrig. door water disapenser
check the switch on the water despensor , solinoid valve or the water supply to the fridge
Apr 13, 2009 | Refrigerators
Whrilpool side by side despenses water but no ice
follow the line down the back sometimes it freezes up. You might have to remove panel behind. try this
Apr 10, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Door panel doesnt work
Check circuit fuse,electrical connections,check your door circuit & buttons.
Feb 21, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Ice maker working, but no water despensing
The water tube is frozen at a point about 2-4 inches from where it comes out of the door. GE has a heater kit available to repair this by calling GE Parts 1-800-626-2002 or online at www.geappliances.com. It is pretty easy to install but you might want to allow a GE factory technician to take care of it since it involves pulling the dispenser PC board off and changing a couple of wires around. GE Factory Service: 1-800-GE-CARES (1-800-432-2737)
Dec 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Ice despenser not working
use a hair dryer, it will thaw the ice and not damage the plastic
Apr 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore Side by Side Model 253-56953601
does it have a lockout on the despenser area that you can push to reactivate the despenser
Apr 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice despenser
will it still dispense the whole cube?theres a brass rod under yourice bucket, remove bucket and check that rod, should be spring loaded and have a little bit of action(youll see it move a flap in front of bucket as its twisted, if so make sure the bucket is being reinstlled correctly, try the dispensor w/o the bucket installed at all, open the door trip the switch with one hand and depress the plunger for both crushed and cubed and check for the motor to turn
Feb 22, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
147 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
