Tv out of focus
Happy new year i brought a used sony tv kp61hs10 and was told that the picture and words will be out of focusfor the frist 10 to 20 mins and then every thing will be fineits been 2 mths same problem no change after 5 hrs.can someone help many thanks sid
  • 5,138 Answers
You need to replace Both of the convergence ICs STK392-560s they are big black ICs. www.electronix.com for parts 1-800-223-3205
Posted on Jan 01, 2009
Well I got a used tamron 28-75mm f/2.8 lens and I was told It has BIM so it can focus on my d3100 and well.. idk how to turn on the af? just a simple question
Nice lens, there should be a switch on the lens barrel fitted close to the camera body when the lens is mounted. It's between the 50 and 60mm focal length markings I'm going to add a picture but not sure how well it will show up. Also the newer Nikon's have some tricky auto focus motor that's fussy to what lens it's capable on auto focusing here is the picture. Happy New yeartri3mast_50.jpg
Dec 31, 2010 | Cameras
Focus is off...at first it was all the colors separated I pushed the flash focus button and it straighted up some but is still slightly off...Sony model#KP61HS10 mfg. 9/2000
There is problem with your tv C board Base.First check it there is fungus if yes then replaced it with good one if still problem then focus block or fbt fautly.
Oct 28, 2010 | Sony Televison & Video
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
Convert my Sony kp61hs10 HD Ready to receive HDTV
no need to convert ,,i have same tv,,hdready just means it has no built in converter. You just need a HD converter box or a cable box or dvr that is also an HD receiver.
Dec 14, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony kp61hs10 tv picture wont line up
THIS PROBLEM IS CALLED CONVERGENCE ...MOST OF THE PROBLEMS ARE CAUSE BY CONV. IC'S GOING BAD AND POSSIBLY A FUSE BLOWN-- U NEED A TCEH FOR THIS REPAIR..TUNICA
Oct 29, 2008 | Televison & Video
Sony 62" Power TV Problem
Is your model KP61HS10? If so I can help you?
Jan 13, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony REar Proj. mOdel KP61HS10
I may be able to help you figure this out. My specialty is Sony, mitsubishi and panasonic. Are you planning on repairing the TV yourself, Can you solder? Let me know .
Jan 13, 2008 | Televison & Video
KV-32s26 Out of Focus, Green, flickers off and on
I regret to tell you that he is probably right. The problem is the trinitron picture tube. Sony advertised it with such high esteem for years and wouldn't doubt that they would do that. The phospher is burned out in the tube and the guns (red, green and blue) are weak and the focus electrobes in the tube are also weak although Sony made it a lot different that any other tube requiring extra circuitry. There is no fix for this. If you could bypass the blacking out you would still have the bad out of focus picture problem
Jan 01, 2008 | Sony KV-32S26 32" TV
Sony KP61HS10 61 in - out of focus when first turned on
He probably went into the Service Menu by Pressing Display,5,Vol+,Power buttons and adjusted the red convergence and that may have lasted alittle while, but the problem seem to be going blurry and then when warming up comes back ok. This indicates a Leaky Capacitor. My question would be is it only Red that is Blurry or is it all colors. It could also be a CRT problem. Could you take a picture of it when it's doing it?
Oct 07, 2007 | Sony KP-61HS10 61" Rear Projection...
Picture flickers off and on
I would try adjusting the screen control on the flyback. The flyback can be easly located, find the red wire attached to the top of the picture tube & follow it down to the flyback. on the flyback you should find two controls, one screen & one focus. you sould be able to read the words above each control, only adjust the screen one. slightly increase the control till the picture stays on, if you turn it too much you will get small white lines going across the screen. Now if what i have told you fixes the set, then it is only a tempoary repair. could last days or mothes, maybe years. if it starts to happen again later the set will have to be replaced. this is a sign of the picture tube starting to get a weak. ALSO DO NOT PLAY WITH THE RED WIRE IT CARRES VERY HIGH VOLTAGES EVEN WHAN UNPLUGGED FOR DAYS.
Oct 30, 2006 | Sony FD Trinitron KD-36XS955 36" TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
