Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
4 button spa switch
You just answered a question I had. Do I disconnect the 4 position button at the spa? It is not under water.
  • hightowerl Jan 01, 2009
    I know this switch is a low voltage. I have above water line but there must be a short in the switch. I do not use this switch at the spa. How do you disconnect the wiring from the switch? t looks like it is wired directly in the switch and switch does not seem to come apart.
  • hightowerl Jan 02, 2009
    Still need to know how to undo wiring to switch? Switch doesn't come apart. Problem does seem to be in switch though.
    Thanks
    Novelist:
  • 163 Answers
Yes, you have to disconnect the 4 position button.
Note: make sure the button is not under the water.
Thanks for your question.
Posted on Jan 01, 2009
  • ronny2051 Jan 02, 2009
    for switching off power, its better to shut down whole house power supply by using main power board.
I have a Aqualink RS6. When I push the "Spa" button to circulate water from the spa, to the heater, back to the spa, then the spa begins to empty! What do I fix or replace?
it sounds as if the actuator returning the water to the spa is not responding. when you hit spa, the 'draw' and 'return' valves must be in the right position. if the draw switches to spa but the return stays on pool, the spa will drain
Jul 19, 2014 | Jandy AquaLink RS2/6 All Button Dual...
What is the right switch position to be when i have spa and pool together
If you are asking if you should have the pool or spa button on, then the answer would be pool. Pool mode creates suction from be pool and should be set up to return to both the pool and spa. This setup allows all the water to be filtered and or heated at the same time.
May 29, 2014 | Jandy Aqualink Rs4 One Touch Control...
My controller says it is in spa mode - trying to heat only spa- but water is spilling into pool. I have 2 jandy valves, only 1 moves when I change from spa/pool mode. Any suggestions?
The valve actuator on the suction side is either bad or the toggle switch on the back is in the wrong position. There are 3 positions for the switch on/off/on. It should be in either be all the way up or all the way down. In spa mode move the toggle switch. If it still doesn't move then you have a bad actuator. If it moves someone has moved the switch.
Oct 21, 2013 | Jandy LAARS VALVE, PRESSURE RELIEF 75PSI...
Jandy pda time keeps resetting back to default and the spa blower will turn on and off by itself
go to system set up see if programs if you have a 4 button spa remote disconnect and see if it goes away sometimes they get water in the wiring no programs are stored in the PDA
Jun 09, 2013 | Jandy Aqualink Pda Ps8 Wireless Handheld...
Spa won't heat unless in spa mode, and if it is in
On the automated valves there are tiny switches on one end or under the valve actuator. When you switch to the spa mode the suction valve should should move to fully block pool drains. The return valve should fully block the pipes to the pool returns and spa fountain. If one or both of these valves is not fully blocking the pipes to the pool then the tiny switch on that valve is in the wrong position or an operator is defective. The middle position of either of these switches turns the operator completely off so it cannot move. That is the position to avoid unless you want to operate it manually. One of the other switch positions caused the valve to move in one direction and the other switch positions causes the valve to move in the other direction. If you set the switches so when in the spa mode water is circulating only in the spa then you have the valves in the right position. Next, place the system into the pool mode. Both valves should move to the other position. If not then the valve operator that doesn't move has a problem. It could be the operator, the wiring, the control panel or a stuck valve in that order. All of this sounds complicated but once you know how the operators should act when you flip those tiny switches and how the valves should act when in the spa and the pool mode then getting the switches set right is simple. I hope this helps.
Aug 07, 2011 | Jandy Pool & Spa
Just bought house with aqualink pool spa, one of our teenagers pushed the buttons, we dont know which one and the spa has emptied and the pool is full and we dont know how to get the water back in the spa...
You cannot drain the spa using the indoor controller, unless the valves out at the equipment are set wrong. go to the outside pannel and put the system in" service mode"(using the button on the left). then push the button on the right till it says "spa fill".There are 2 "accuators" (or automated valve turners) They are black rectangular boxes connected to the water valves. Use the toggle switches on the side to turn the vales to the correct positions. You want the pump to **** from the pool and return to the spa. Now turn on the filter pump and let it run till the spa is full. Put the system back in "auto mode" and you are done.
Oct 28, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy aqua link main control box
Do you have a 4 button switch in the spa and is the light on the button that is slightly under water? If so , the button is bad as the water is completing the circuit and turning the light on and off.
Repalce the button or disconnect it at the outdoor panel.
Oct 28, 2008 | Jandy AQUALINK RS TELELINK KIT
Tub pump
This may be due to clogged jets. Also, if this is a new application....the valves under the spa may not be in the up position to release the water to run into the pump and through to the jets. It may be a top side control issue as well. Check for error codes.
Sep 16, 2008 | Waterway 4 Hp 230 Volt 1 Speed Side...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
123 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
