Question about Sony KP-57HW40 57" Rear Projection Television
Sony kp51 ws500 red screen, 8 blinks
Sony kp51 ws 500 projection tv
when turned on screen almost immediatley goes to solid red with
no discernible details to be seen then totally shuts off after about
20 - 25 seconds. red light blinks 8 times , pauses and blinks 8 times
again and again.......
  • Anonymous Jan 20, 2009
    i have the same tv, same problem, and dont know how to fix it. if anyone can help it would be great
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Symptoms show that either Red-Gun (red CRT) or its drive circuit is defective so thats why TV gives solid red on screen and goes to shutt off.
    Shutt off is protective mode and when ever tv will get serious problem, will go to shutt down by its system control chip.
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Posted on May 04, 2009
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Sony kp-ws500 has very fine red and blue horizontal lines across screen tried adjusting convergence, and it didn't do anything
Red and Blue Tube screen drive controls needs to be turned down some, tubes are over driving causeing drive lines.
Sep 16, 2010 | Sony KP-65WS500 65" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
KP-57WS500 8 blinks will not power on
8 blink error code is usually indicating that the HV transformer ( Flyback) is faulty on the D board. You can get a replacement flyback at the following link with free tech support to explain how to replace it. Heres a link to the correct Flyback for the KP51-65WS500 model sonys.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-flyback-145328541/cName/flybacks
Jan 04, 2009 | Televison & Video
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
KP-57WS500 TV FADES TO SOLID RED W/ LINES A FEW SECONDS AFTER I TURN IT ON
Red CRT is doing short circuit in the neck. You can try to open the front panel and to hit easy the neck with wood or something and to decrease the red screen a bit. If doesn't work then replace the CRT.
Jan 04, 2008 | Sony KP-57WS500 57" Rear Projection...
57xbr2....tv turns on briefly...solid color screen for a second...then blank?
I had the same problem about a 8 months ago. I searched online and found that there is a problem with one of the color guns. They need to be replaced. I don't remember where I found the information, but there is a number or something to call for this problem. I think that my authorized sony repair man knew of the problem, there are other models that have the same problem. Anyway, sony replaced all three guns in my tv FREE of charge, and my tv was no longer under warranty. They did all repairs and fixed my tv.
Aug 25, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony KP-57HW40 57" Rear Projection Television Logo
741 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
