Question about Motorola Mobility RAZR V3
BLUETOOTH MODULE NOT ATTACHED
I am not able to connect my bluetooth headset to my phone. I keep getting message: Bluetooth Module Not Attached.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 113 Answers
You need to switch on bluetooth headset with battery charged enough. also you need to put bluetooth in search mode to pair it with phone. see manual which came with bluetooth to get it in search mode.
Posted on Jan 01, 2009
I keep getting the message "Bluetooth linke is busy". What does that mean?
When you get a message like that on any cellular device, smartphone or iPhone...its because your bluetooth device is experiencing errors internally, or either your bluetooth device is connected presently with another device and keep in mind that bluetooth can only connect to one device at a time; meaning that if your bluetooth device is connected presently to any other device, that connection should be terminated in order for bluetooth to be able to search and connect to a new device!
Before you take any of these steps make sure that you have your Bluetooth settings in your phone are set secure; make sure that if any device is trying to connect, would get your attention ( any connection attempted will be prompted on your phones screen) by doing so you will not have outsiders connection to your phone without your permission!
Solution = Turn off your cellular device, and turn it on again! If you're able to remove the battery and placing it again please do so but however some devices like iphones, batteries can not be accessed! ( with such devices, using the Power On/Off botton is good enough to reset the device ).
Power off your Bluetooth headset! ( Do not turn on your device yet)
make sure your bluetooth settings in your phone is not set to automatically connect to any other bluetooth enabled device!
after your phones reset, turn on the headset using the middle botton wich is the round botton, and hold until you get a solid light and make sure BLUETOOTH IS ENABLED AND DISCOVARABLE!
if that doesn't work, hollar at me!
Sep 15, 2010 | Jabra BT2050 Bluetooth Headset
I forgot how to set my h700 motorola bluetooth to my new phone
Well you can please follow the below steps -
1. Gather and charge your cell phone and bluetooth headset.
2. Put your bluetooth headset in "pairing mode". For almost all headsets this is done by starting with the headset power off, then pressing and holding the multi-function button (the button you press to answer a call) for a few seconds. First, a light will blink showing you that the unit is on (keep holding the button) and a few seconds later, the LED on the headset will blink in alternating colors (often red-blue, but this can be anything really). The blinking lights indicate that the headset is in pairing mode.
3. Use the cell phone to "find" the headset. Usually this is a setting in the menus of the phone, and it's different for each phone. Most newer phones will have some kind of "bluetooth setup" menu. Older phones may have this menu buried in the general phone settings.
4. Provide a PIN code. When the phone "finds" the headset, it will ask for a PIN code. Most of headsets, this code is "0000". Enter 0000 into the cell phone when prompted.
5. Wait for a message. The phone and headset should connect and you should get a connection message on the phone. It should say something like "Hands Free Connection Established" or something along those lines.
6. The headset and phone are now paired.
Good Luck!!
Mar 31, 2010 | Motorola Mobility H700 Wireless Headset
Moto razr3v bluetooth system doesn't work
probably pairing problem. You need to pair your bluetooth with the phone again. There are video instructions on the exact steps on www.HandBookLive.com under Electronics category (Bluetooth)
Mar 01, 2009 | Motorola Mobility RAZR V3
Can't get my bluetooth to work with my phone anymore.
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select BT350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 31, 2008 | Jabra BT350 Bluetooth Headset Headset
Bluetooth connection
First I would need to know the model Bluetooth you have so I could tell you what to do to reset the headset. You can always reset a bluetooth headset to repair it to another device. Normally though to reset a bluetooth headset, you would have to power the Bluetooth device off and then press and hold the device to get it in pairing mode. Usually when in pairing mode the device's light usually stays lit a solid color such as red or purple, or it flashes two different colors simultaneously. At that point you can get your device to find the headset (make sure that you device is bluetooth capable, is on, and is visible to devices) and then pair it. There is always a passcode or pin associated with the headset which creates a secure connection between your device and your bluetooth headset. The default pin code is 0000. Hope you get it working, if it doesn't shoot me a message with the make and model of the bluetooth headset and I can walk you through it.
Dec 17, 2008 | Cell Phones
I lose my Bluetooth connection, and the problem is with the phone
You will need now to take the phone and have the firmware reflash in the phone.
Dec 10, 2008 | Motorola Mobility RAZR V3
How to connect the bluetooth??
I used this Motorola Bluetooth manual to connect my Motorola N136/HS 850 to my LG PM 325 phone. In the attached manual: Go to "using your headset" - "linking your headset and phone" and follow the instructions. You may need to revise the steps slightly to fit the functions of your phone. I followed steps 1 and 2, skipped step 3 and instead found the bluetooth icon on my phone, selected "add new", then selected "searching and pairing" and allowed the phone to search for and pair my bluetooth device. The Motorola Bluetooth device appeared on the screen of my phone within seconds as "Motorola HS850". I selected the device on the screen of my phone and followed step 5 entering the pin code "0000" and selected "connect" on my phone to begin using my bluetooth. I hope this helps someone. Use the following link to access the manual: http://www.usersmanualguide.com/motorola/accessories/bluetooth_wireless_headset
Aug 05, 2008 | Motorola Mobility Bluetooth Hands-Free...
Bluetooth module not attached
4.Select H500 once a connection is detected.
Tips:
Jun 27, 2008 | Motorola Mobility H500 Wireless Headset
Bluetooth module not attached !
try this,., delete old pairing for ur bluetooth, and re- pair it again...gudluck
May 10, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
93 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
