Question about NetGear DG834G Router
Securing wireless connection
Hi, you helped me out with a problem earlier which was great but you also said about securing my wireless connection. How do I go about doing this?
Thanks Mark
  • 104 Answers
Hi again, glad to help if I can.
Securing the wireless signal will temporarily disconnect the PS3, which will need to be set up with the new security details in order to connect again.
There are four steps, which are the same for most routers:
1) Login to your router, using a wired connection
2) Change the router login password 3) Change the network name (SSID)
3) Enable WPA encryption
Here are the details:
1) Login to your router, using a wired connection.
On your desktop PC, open a web browser, as if to view a web page. Type the router address into the address bar, which is http://192.168.0.1 for this model. You can also use www.routerlogin.com for Netgear.
You should then see a popup box, prompting you for a username and password. If these have not been changed, they will be the defaults of username: admin and password: password
If you log in successfully, you should then see the Netgear configuration screen.
2) Change the router login password.
To set a new password, go to the left hand menu: under ‘Maintenance’ click ‘Set Password’. Set and confirm a new password. Click ‘Apply’ when finished.
Make sure this is not easy to guess, otherwise someone could login to your router and view/change your settings. (Tip: write the password on a label and stick it on the router, or keep it somewhere safe. )
3) Change the SSID (router name):
Go to Setup > Wireless Settings. Under ‘Wireless Network’ you should see an option marked ‘Name’ or SSID. Change this from the default, ‘netgear’, to anything you like, that you can remember. You will need this when setting up the PS3 again. It is case sensitive, and you can use up to 32 letters –but do not use something that could identify you, or your location.
4) Enable encryption
Still in the 'Wireless Settings' menu option, you should see the ‘Security Options’ section. You have a number of options, but I would pick WPA-PSK, which is very secure and good for most equipment.
Under ‘WPA-PSK Security Encryption’ you need to enter a network key. This is a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappynEWYeartoyou8899). It is case sensitive.
Note down the network key carefully. You will need this to connect wirelessly. (The network key may also be called the WPA shared key, PSK, pre-shared key, passphrase, or authentication key.) Click ‘Apply’ when finished.
That's it, you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, or go to configure the PS3, a scan should bring up the router with its new name in the 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if it doesn't, or if you need help with any of it. Good luck!
Posted on Jan 01, 2009
  • eecom Jan 01, 2009
    Hi again, I've tailored these instructions for the DG834G model, and your original posting mentions the DG834GT, sorry. The instructions are essentially the same though (except 'www.routerlogin.com' won't work for the GT model.)
    Please drop me a line if anything else is not as expected. Thanks.
Can you help me setting up a password for my wi-fi connection using netgear router
How do I secure my network?
Log into your router using the "How do I log into my router?" instructions earlier in this article.
  1. From the left-hand menu, select Wireless Settings from the Set Up section.
  2. In the Name (SSID) field, enter the network name you want to use.
  3. Under Security Options, select a security encryption level. NETGEAR recommends WPA-PSK + WPA2-PSK for the best protection.
  4. In the Passphrase field, enter your chosen network password.
  5. Click the Apply button to save your changes.
For more details, see Securing Your Network: WPA+WPA2 (Recommended).
How do I change or reset my wireless network password?
Log into your router using the "How do I log into my router?" instructions earlier in this article. From the left-hand menu, select Wireless Settings from the Set Up section. Enter a new wireless network password into the Passphrase field under your security selection and click the Apply button to save your changes.
Jun 05, 2011 | NetGear WGR614 Wireless Router
Just want to know how you secure your connection, do you need some sort of password?
Hi!
Securing a networks require setting up a passphrase or password for wireless connection which can be configured on your router setting.
You may call your router manufacturer or visit their website for step by step instruction.
Hope this helps.
May 16, 2011 | HP Computers & Internet
Network is "out of range" only after securing my wireless network
reset your router
should be a reset button on the back,
hold in till the lights on the front flash then its reset open explorer browser
type in 10.1.1.1 or 10.0.0.1
log in as Administrator
add new user
set password while adding new user
save your new settings(write them down too)
run your network wizard again with your new settings applied
test the internet for function
if no function then contact your ISP to assist with connection to internet
all sorted now please rate me MISTERDJ
Apr 11, 2010 | Toshiba (PA3070U-1MPC) 802.11b Wireless...
Securing my network
OK, what you might wanna do is this. Ask the friend who installed the router for you what the home page IP address of the router is. After attaining that information, open up internet explorer (or firefox), and enter that address (usually something like 192.168.1.100 or something like that).
Assuming you're using a linksys wireless router, look for anything that has the word "security" on it. Click on that tab. After that, choose wep encryption option (think the latest one comes with WPA-AES2 option). The page will then prompt you to type in a password. YOU MUST REMEMBER THIS PASSWORD. After that is settled, click on save and exit the page.
Now go to your laptop and try to connect to the router. It should prompt you for a password before connecting. Enter the password (the same one configured earlier) and by right, you should be able to connect to the router. "Ask me" if you face any further issues k? Thanks
Best Regards,
Technomancer
Jan 08, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Securing my belkin router with a network key
ok...
first you need to find the default gateway of the router,u need to do this settings in the computer which is wired to the router,securing the network over a wireless connections is not suggested..
click on start,run,and type in cmd,hit enter,a black box should appear in that box type in ipconfig and hit enter,once you hit enter it will give u a lot of results check the default gateway the generic default gateway is 192.168.2.1,might be different in your case incase if you have setup in a different manner,now open an internet explorer page and remove the website name that present in the addess box,now without http or www type in the numbers,it will tell you to put in the user name and password,username is admin and password is blank (this is generic to all the belkin routers provided you have not changed it earlier,if u ave changed it then put in the user name and password that you have setup,now it should open a belkin router page,now in that router page you will see an option that will says wireless,under wireless you will see an option that says security,click on security,and then under security page you will see security mode,from here you can use the security type that you want to use and then save the changes once it has saved the changes you wireless netwokr will be secured.
PS:make sure the computer is connected with a wire to the router when we are setting the security in the wireless network....
vedhick.........
Feb 20, 2009 | Belkin (F5D7230-4) Router (587009)
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
Problem securing belkin wireless g plus router
you must enter the WEP key because if type in the pass-phrase it won't connect(don't know why)
Jul 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Securing a wireless network
use the ethernet cable..go to the website, and print out the instructions..
May 24, 2008 | Computers & Internet
Security
That is very likely Jeannie. Do you know if you have your wireless network secured? If not, then that is most certianly what happened. If you need assistance securing your connection let me know!
Jan 10, 2008 | Linksys Wireless-G Broadband Router
Securing my wireless connection
Hi ladynb,
Open the DI-524 window by typing 192.168.0.1 into internet explorer address bar, and press enter.  Fill in your password, and press enter.  Click on the  Wireless button. This should open the Wireless Settings window for the 524.  Set SSID broadcast to  Enabled. Set Security to WEP.  Set Authentication to open system.  Set WEP Encryption to 64bit.   Set Type to HEX. Click and select radio button next to KEY1.  Enter a 10 digit number that you can remember, like 1234567890, or 1111122222.   Now click the Apply button at bottom of the screen.
Now any device that you wish to link  will will need to use this Key.   Scan for the router, connect and use Infrastructure mode, Type in the 10 digit number you were suppose to remember, and off you go.
Oct 09, 2007 | D-Link AirPlus DI-524 Wireless Router
NetGear DG834G Router Logo
83 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
