Question about Canon PIXMA MP810 All-In-One InkJet Printer
MP810 error 6B00
It's me again, the one with the Canon MP810: the error popped up the moment we put the plug in the socket, without even connecting it to the computer - this was the order of the steps of the Quick Install recommended by Canon. Any recommendation from your side? Thanks for helping - Happy 2009!
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
I have a canon MP810 it is coming up with error code 6B00, what does this mean ?
You probably have something stuck in the paper feed or under the print head.
First try moving the print head left and right with the printer off. If that doesn't work then, Try looking for jam in the paper feed and specifically under the rollers. A small piece of paper or other debris, like fallen paper clip, staple. postage stamp are things I have seen stuck in printers that cause jams and error codes.
If these solutions don't work, post comment here.
j
Feb 21, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Canon Pixma Mp810 won't turn on, any suggestions
I had the same problem. Everything was working fine one day, but when I tried to switch it on the next day, nothing! The status light came on green briefly but then turned off. I thought the power module might be blown so I ordered a new one, that changed nothing, my printer was still completely dead, showing no sign of working at all.
I dismantled it to inspect every component for signs of failure, everything looked like new. Having read that the print heads can fail (dry out then blow) on canon printers, I tried starting the printer without the printhead and hey presto, it turned on and went through it's startup cycle. After making whirring sounds for a while a message popped up telling me that there was no printhead installed. As soon as I reinserted the printhead the printer turned off and wouldn't turn on again, even if I removed the printhead again (and unplugged/waited etc). I had to unplug and then re-plug a connector on the printer's motherboard to get back to the stage when the printer would turn on (without the printhead).
I have inspected the printhead with high powered magnification and found nothing unusual - a new printhead is about $100! My final conclusion is that there is nothing actually "wrong" with the printer but rather that it is a case of programmed obsolescence. My printer is about 5 years old (like new) and in the service manual that is the prescribed lifetime for the printer, so it's designed to simple stop working after that time.
PS. I did do the ink well reset procedure, didn't help.
Mar 19, 2010 | Canon PIXMA MP810 All-In-One InkJet...
Canon MP520 error U051 insert print head, no print head. This is a new printer that was not used for 4 Months. What do I do?
The printer not recognize the print head at the moment.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Clean the contacts using cotton and some alcohol.Then put all back and try again.If this not help you need to replace the print head.It's part number is QY6-0070
Oct 30, 2009 | Canon PIXMA MP810 All-In-One InkJet...
IP4000 service error 6B00
6B00 is a paper feed error, look in the back with a mirror and flashlight, and see if something has fallen in where you put the paper for printing.
Jul 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error 6B00 and error 5110
It means the carriage is not lifting and and the paper feed can not run. Sounds like either a paper jam inside or something fell in that doesn't belong. A flashlight and small mirror will help you look inside.
Jun 26, 2009 | Canon PIXMA MP810 All-In-One InkJet...
Mp810 Canon error 6B00
Try the following : GO through the control panel and delete the printer completely. No try to install a new printer using the windows install. When it asked if you have the disk let uit find the install disk and install it . If this doesn;t now work. go back to the support website  and/ or the litature you have that came with the printer and see/ confirm that the windows version you are suing is the same as the one that yo have the install disk for. If not dowenload the correct driver from Canons web site.lf all that fails,since it is  new, return ikt for another.
Jan 01, 2009 | Canon PIXMA MP810 All-In-One InkJet...
How do I resolve Error U150 on Canon MP810?
have had a MP810 about 3 months. Recently I've been getting a U150 error message. My C tank is not lighting up and being recognised. When I open up and replace the tank the light comes on. Initially this allowed me to carry on printing but now I have a constant error message even after replacing the tank.
Is there a permanent solution to this annoying problem?
I would be grateful for any assistance.
May 29, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Error code 6000
Hi there, every time I turn on my printer, it keeps saying error 6B00
Any halp for me Canon PM810
Apr 14, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Error code 5010
There's no specific info on a 5010 error even on Canon website, but ANY error in between 5000-9999 needs Canon's attention, so if it's under warranty, get a replacement.
Feb 17, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Pixma mp810 paper jam?
Go inside the unit, the jam is most likely to be a very small torn shred of paper, near the carriage roller or similar. Us ea torch if the room is not bright enough, this helps fing it.
Feb 13, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
111 people viewed this question
old marine
old marine
