Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
1995 Chevy Cheyenne/K2500 Pickup Won't Start
This morning when I tried to start my '95 Chevy Cheyenne 5.7L V8 pickup, it wouldn't start. I assumed I had a dead battery but the dash, interior dome and headlights all worked when I turned them on.
I used jumper cables to try and start the truck but all I got was a "clicking" sound from the engine compartment. The motor won't even crank. I'm assuming the starter/starter solenoid is shot.
If it is the starter, is this a repair I can do myself?
Any suggestions?
Don
  • Bulldog Secu... Master
  • 5,568 Answers
Hi Don,
Using lights to check battery condition isn't a good test; you might get a 20 amp drain from those versus 100-150 amps the starter draws.
Without checking a few things, you may be buying a starter for no reason. Jumping your battery won't help if the battery clamps to which you connected or the terminal lug on the starter is corroded. One half of an Ohm on any terminal will drop 75 volts at 150 amps the starter wants to draw and you have only 12 volts available so you can see how critical clean connections are to the starting process.
You can probably verify a crappy connection by turning on lights and then attempting to start; if the connection failure is at the battery, the lights will dim or go out completely. If the connection is bad at the + starter terminal, the lights won't change appreciably in brightness. The same however, applies to a failed starter or solenoid.
I recommend to everyone that they buy a cheap digital multimeter for use around the home and cars. They can be had for <$20 US at auto parts stores or, in the US, at Radio Shack. If you have a Harbor Freight tool store in your area, you can buy one for under $10 and I have bought three for $3 each. They come with Chinglish instructions that will suffice for most users and one need not be a expert to use one of these.
Posted on Jan 01, 2009
  • 15,935 Answers
Yes there's lots of soom under a pickup to work. It can be done with common hand tools. 2-3 bolts hold the starter in place, and unplug a wire harness. Thats it.
Before replacing, try tapping on the solenoid with a hammer, it may be a little corroded or stuck, it may loosen up and get you a few more days/weeks of service.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Chevy transfercase I have 1995 2 door cab 2500 what years will work
gmc and chevy k1500 pickup and suburban years 95-99
k2500 pickup years 95-98
k2500 suburban 95-96
gmc k2500 and yukon 95-98
I hope that helps if so please rate my answer
Dec 26, 2014 | 1995 Chevrolet C2500
Will 1995 half ton fit 1995 three quarter ton tranfercase
Dec 26, 2014 | Cars & Trucks
Chevy c1500 no spark
I agree, the ECM
Jan 08, 2014 | Cars & Trucks
No spark 1998 chevy cheyenne 2500
Have you changed the pickup unit inside the distributor? The rotor?
The distributor cap?
Nov 22, 2012 | 1995-1997 Chevy 1500 Truck Ignition...
New battery, new alternator, new starter, still won't start, 1994 chevy cheyenne 5.57 v8 ck2500
Get a fuel pressure gauge and measure on the fuel supply line on the rear of the inlet manifold. In my experience you need close to 4Bar while cranking. Priming pressure should be about 4.4Bar. This test will eliminate a variety of possible problems. I need more history to be more specific.
Oct 09, 2010 | 1994 Chevrolet K2500
Transmission on my 2000 chevy k2500 4x4 pickup
your transmission has possibly been rebuilt with stronger springs put in. No worries. have been running mine for along while without any problems. Better this than slipping, but it is a bit annoying.
Jun 08, 2009 | 2001 Chevrolet Silverado 2500HD
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
947 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
