Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon MP160 leaving streaks
I have performed all the cleaning methods in maintenance two and three times each, and I have cleaned excess ink from ink cartridges. The streaking is exactly the same as when it first started. Also, the streaks are in the exact same place on the page every time (I am using the same page every time I test print
  • Anonymous Jan 02, 2009
    I have exactly the same problem with my MP160 !
    President:
  • 8,637 Answers
Normal 0 This has fixed a number of printers and worth a try
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
Page prints with black streaks
Black streaks are more then likely caused by dirt, dust and dry ink. Try using a damp cloth and clean the excess dirt/ink. Some printers have an auto clean setting, try that as well!
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
May 05, 2010 | Canon imageCLASS MF8170C All-In-One Laser...
Hi, (MX850) My blue ink has stopped printing. I
Performing Maintenance:
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
Step 1
Printing the Nozzle Check Pattern.
If lines are missing or if white streaks appear
Step 2
Print Head Cleaning.
If the problem is not resolved after performing Print Head Cleaning twice
After cleaning the Print Head, print and examine the nozzle check pattern (Step 1) again.
Step 3
Print Head Deep Cleaning.
If Print Head Deep Cleaning does not resolve the problem, turn off the machine and perform another Print Head Deep Cleaning after 24 hours. If the problem is still not resolved and if you are sure that the ink didn't run out, then the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
All the best.
Mar 11, 2010 | Canon PIXMA MX850 Multifunction Printer
Canon pixma mp140 not printing correctly
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 11, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink on back
I take this printer is not under warranty, have your tried rubbing alcohol and cutips, works for me sometimes.
Nov 09, 2009 | Canon Pixma MP950 All-In-One InkJet...
Photos printed come out faint and lines andblack streaks across the photos how do i solve this/
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Print quality can be improved by performing print head cleanings or print head deep cleanings. aution: Only used the approved methods below to clean the print head. Use of other methods may further clog the nozzles on the print head and may cause permanent damage the print head.
Note: It is important to check the cleaning results by printing Nozzle Check Pattern after each cleaning. Cleaning and Deep Cleaning consumes a certain amount of ink. Only perform a cleanings when necessary.
Print a Nozzle Check Pattern
  1. Confirm that the printer is connected to the computer and the printer is turned on.
  2. Complete or cancel any print jobs in progress.
  3. Open the Printers folder.
  4. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  5. Insert a piece of letter-sized plain paper in the paper tray.
  6. Verify the desired paper source for the Nozzle Check is selected on the unit by changing the Paper Feed Switch if necessary.
  7. Select 'Nozzle Check'.
Aug 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Xerox Phaser 8560, produces cyan colored streaks whenever this ink is used. No other colors produce streaks.
You are probably using "Media Sciences" ink sticks (Non-Xerox).
This means the printheads jets are clogged, and the printhead needs replacing.
Media Sciences released a defective lot of cyan ink sticks.
They are currently replacing printheads (at their cost) if you call them.
Aug 12, 2009 | Xerox Phaser 8560DN Laser Printer
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon i560 photo printer: leaves a purple streak on the right side of my 4 x 6 digital prints
Remove the cartridges and do a through cleaning use cotton bud to clean the cartridge nozzles...clean the service station area well(this is where the cartridge rests on the side of the printer)....wipe of any spilled...excess ink you can see....
keep me posted
cheers
Nov 14, 2008 | Office Equipment & Supplies
Canon mp160 prints not alligned and dirty
put in canon ink, possible stuffed head if been using non oem ink
Jan 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
113 people viewed this question
old marine
old marine
