Question about Kodak EASYSHARE 5100 All-In-One Printer
Printer will not print with black ink.
My Kodak 5100 will not print anything that requires black ink. I've replaced the both cartridges on two separate occasions, but still no luck. Any suggestions before I toss it out in the garbage?? It's not even a year old.
    President:
  • 2,976 Answers
Contact Kodak. My printhead failed on the black side. They replaced it without any questions. Hopefully you registered the printer when you bought it. It is your warranty.
Posted on Jan 01, 2009
Can the printer print with just a black ink cartridge?
The KODAK All-in-One Printer uses an advanced built-in printhead. The system is designed to provide excellent image and text quality, while eliminating the need to purchase new printheads every time you replace ink cartridges, and saving you money. The printing system requires that both the black and color ink cartridges be installed to print. If either cartridge is not installed or is out of ink, the printer or printhead will not print correctly.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 19, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
You can barely read anything that is printed from my Kodak 5100 printer. I have replaced both the color and black ink cartridges. What do I try now?
Printhead clean, done from the maintenance on the printers software. Also if that doesnt help, contact the printer manufacturer for a replacement printhead.
May 11, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 Needs Both Cartridges To Print?
Unfortunately, you cannot used the printer if one of the ink cartridge is empty., compare to the other printers you can print a black text or gray scale if the color is empty or one of the cartridge is empty.
All kodak printers work the same both cartridges should have ink on ink before you can use It.
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
I changed the ink cartridges printed properly once now no black. printer says ink is full but fuzzy and no black?
Here are the steps.
1.Please verify that the ink cartridges are intact and securely inserted into the printhead.
a.Lift the printer access door, then remove the ink cartridges from the printhead
b.Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
c.Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
2.Clean the printhead.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} a. On your computer, open your Kodak AiO Home Center software.
b. Click on the Help (?) button.
c. Click on the Maintenance option.
Click on the Clean Printhead option
3.Print Demo Page.
Press Photo and Copy buttons at the same time for 2-3 seconds or until the printer starts printing then release the buttons.
If issue persists,the printhead on your printer require replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Sep 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I have a Kodak 5100 all in one printer, I just replaced the black ink cartridge and now it won't print anything but come black lines. How can I fix this?
hi there,
you have to check some of the possible cause why the print won't print:
  • make sure that the ink was properly seated on the carriage.
  • do a printer head cleaning. do deep printer head cleaning using the printer utilities installed on your PC.
just let me know for further clarification, k.
May 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
Mar 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Check Black Ink blinking...???
Remove the ink cartridges
Remove the printhead
Close the access door w/o anything in the printer
wait for a few minutes
Install the printhead only
install the color ink cartridge
install the black ink cartridge
if the error still there ( Repeat the cycle 5x)
or go to www.kodak.com/go/itg
Mar 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My printer will not print anything.
Contact Kodak support from the Kodak webpage. Do the chat online. Sounds to me that it is the printhead. They may find that the printhead needs to be replaced. I did it today and they are sending me a new printhead plus spare ink cartridges for free (2-3) days.
Dec 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printer Kodak Easyshare 5300 Will not print black ink
They overnighted a new printer head and free ink. We already recieved it. AMAZING. Thank you Kodak. They are awesome.
Dec 17, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
