Question about Toshiba Satellite A135-S4527 Notebook
Toshiba laptop My screen went black and will not come on. I can hear the computer running
  • 4 Answers
Do you have a problem with the backlight on your laptop? If yes, youare not alone, that’s one of the most common laptop problems. In mostcases the screen inverter is the culprit. Here are some LCD screen backlight failure symptoms that could be related to a bad inverter board:
- Laptop boots as usual but after some time the screenblacks out. You still can see an image on the screen but it’s very dim.You might even use a flashlight to see it better. Sometimes thebacklight comes back for a while but then goes off again. In some casesyou can turn the backlight on if you tap rapidly on the lid closeswitch.
- The screen always stay black and the backlight never comes on but youstill can make out an image on the LCD. It’s dark, but the image isstill there.
-In some cases you might hear a buzzing noise coming from the areawhere the inverter board is located, it’s on the bottom part of thedisplay assembly.
NOTE: if you cannot see an image on the screen, most likelyyou have a different problem and there is nothing wrong with the screeninverter.
Posted on Feb 05, 2009
Take it to a computer repair shop and have them to order and change out the flourescent fillament behind your screen.I think the cost is alot cheaper going this route rather than. Taking your laptop to best buy and replacing the entire upper lid that probably costs the same as a refurbished laptop.
But if you need it as a temporary fix then just buy another connecting/video output plug and connect it to your tv or another laptop and change the screen resolution.
I hope i was a help tp you!
Posted on Jan 01, 2009
    Novelist:
  • 101 Answers
First test is hold a flashlight at an angle to the screen to see if there is a faint image. If you can see the image with the light then the problem is with the laptop's display, either the backlight went out or the inverter is bad.
Second test is to hook an external monitor by VGA cable. Image should be complete and in full color if the onboard video card is functioning.
Please post comment with results for more direction.
When i turn onToshiba Satellite M100-JG2, get black screen,and hear 2 bee sounds,computer won't start.
Two beeps a generally a memory parity error.
Use a test utility like memtest86 to check it. Youll need another computer with a CDRW to create a test disk from an ISO.
Then boot the computer with the cd in and it should run from CD.
Memtest86 Advanced Memory Diagnostic Tool
Jul 02, 2014 | Toshiba Satellite M100 Notebook
Toshiba satellite pskoqu screen blanking
Please check the air vents (inlet and outlet) and clean them up using a canned air, and use an external monitor to test this laptop. If the problem is not solved, then your laptop's GPU/motherboard is dying.
Mar 09, 2014 | Computers & Internet
No beeps toshiba x200
IF neither your external Monitor or Laptop LCD screen are inactive, this generally relates to the Video Section on the mainboard a being compromised. The best solution is a bench test done by a technical professional to locate the excact cause.
Jan 07, 2014 | Toshiba Satellite X200-AA3 Notebook
Toshiba black screen bios problem
hello
To verify if it's a screen or motherboard problem you need to connect an external monitor to the laptop ,can you hear the laptop enter windows by hearing the welcome sounds if so then its a screen problem.
otherwise the motherboard has to be replaced.
Good Luck
Feb 13, 2012 | Toshiba Computers & Internet
Black Screen ALL MOST, some time it is ok, some time not.!!!!!!!
can you try to Attach an external monitor and check if it has the same problem on the external monitor?
Sep 12, 2009 | Toshiba Satellite M35X-S161 Notebook
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
Jul 21, 2009 | Computers & Internet
Laptop Screen Cuts off, but Computer Stays On
Good chance the is a power saver option if it happens while you are not actually using the computer..
The computer will turn off the monitor after a certain period of inactivity to save power.
Go to the Control Panel, select Power Options and adjust it to what you want.
Sep 27, 2008 | Toshiba Satellite A135-S4527 Notebook
Black screen on gateway 450sx4 laptop
sounds like ,audio card went died or mite be screen has shorted out try hooking it up an orther screen and see if it boots up if so either viedo screen card or screen it self
Jun 02, 2008 | Gateway 450SX4 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
