Faulty CD tray gear
The tray gear whull is broken on my CD player. I understand that it is a CDM4 type. Any ideas where I might be able to find a replacement?
Many thanks
  • Scott Frye
    Scott Frye May 11, 2010
    Hi and Happy New Years,
    If you can get the model number I may be able to help.
    There are Philips parts around.
  • 85 Answers
Check on ebay i belive you can get them from china or japan as original ones were biscuit **** and shattered,replacements are nylon much tougher
Posted on Jan 08, 2009
Door won't open of Technics SL-CH900
Hi Robert,
probably the cd tray belt (a tiny black rubber belt that connect the tray rack with motor gear) is broken, check this by opening the player, if torn you need to buy a new spare and replace it.
May 30, 2016 | Technics Audio Players & Recorders
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
Cd tray stuck
The tray may be jammed, or the timing gear is out of sync, or a broken loaing belt.
Apr 26, 2012 | Teac AD-600 3-Disc CD Changer
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
The dvd drawer will not open
Possible that the mechanism is faulty , the loading motor is faulty or the loading control drive is faulty.
It will be good to open the unit and check the mechanism for any jamming of the drive. make sure the motor gets supply when eject is pressed if not the loading motor control drive IC is faulty provided the mP is giving in the drive voltage to its input pins.
Sep 29, 2010 | Sanyo HV-DX1E DVD Player/VCR
CD tray is not moving in and out easily. Grinding
unplug the unit and open it. the tray is usually controlled by a belt driven by a motor. look and see if the belt is broken. Hopefully yours is not driven by gears.
Oct 24, 2009 | Yamaha CDC-665 CD Player
CD will not eject - it plays fine - but the tray will not open
If the tray mechanism is belt driven, the belt may have become loose or is broken and needs to be replaced (usually the belts are of a standard measure and can be purchased in electronic stores or via internet), but if there are only gears to drive the tray mechanism then it could be broken teeth on a gear wheel, faulty drive motor or faulty motor driver electronics.
Hope you can fix it.
Regards,
Triarcuate
Oct 17, 2009 | Denon DN-C615 CD Player
Mission 7000 CD player
laser is sensitive to dust particles. may be the laser is not working properly.
Sep 18, 2008 | Audio Players & Recorders
216 people viewed this question
 Grubhead
Grubhead
