Question about Canon PowerShot A530 Digital Camera
Hi, I have a Canon Powershot A530 that displays the 'charge batteries now' message, and the batteries (NiMH) are new and fully charged. I've seen postings of a similar nature, but haven't seen a fix. Can you help? (The camera is two years ols, and has only recently been exhibiting this problem)
  • Canon Master
  • 4,738 Answers
Check the following Canon advisory to see if your camera may be shorting out due to the battery door spring. If so, Canon will fix for free:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=12914&keycode=2111&id=28800
Posted on Jan 03, 2009
When i put the new batery it will display "change the batery" and automatically power off the camera
This camera takes AA batteries. You must use good alkaline batteries or better, a set of high capacity NiMH recharegables. Zinc batteries just aren't up to the task.
New rechargeable batteries are supplied only partially charged. You need to charge them fully before use.
Oct 28, 2010 | Canon PowerShot A540 Digital Camera
I just charged my camera's batteries and an error
Your camera is telling you that the batteries have insufficient power. First thing to check is that the battery contacts on both the batteries and inside the camera are bright, clean and free of grease or oil.
Assuming that you're using the original NiMH rechargeable batteries which came with the camera, then you almost certainly need to replace them with new ones as they cannot be reused indefinitely.
To test whether the problem is with your rechargeables or with your camera is very easy. Just buy a set good quality, non rechargeable, alkaline (e.g. Duracell) AA batteries. If the problem disappears then you know that you need to buy new rechargeable NiMH batteries next time.
There is also a small possibility that you have a faulty recharger but it's unlikely. The only way to test it without special tools is to try getting your NiMH batteries charged in a borrowed recharger. If the batteries get fully charged then the error message on your camera will vanish and you'll need to buy a new recharger. Just make sure that the charger is designed for NiMH though or you will damage your batteries and possibly the charger.
Jan 15, 2010 | Canon PowerShot A560 Digital Camera
Canon Powershot A470 - asks to 'change battery' every time it is turned on, then turns off immediately. This is so even when new, fully charged batteries (different brands, rechargeable, non-rechargeable)...
This happened with my Canon Powershot A470. I sent it back to he manufacturer and they said I was using the wrong batteries. Even though the camera is supplied with two alkaline batteries, they recommend using AA NimH rechargable batteries.
Jan 08, 2010 | Canon PowerShot A470 Digital Camera
After one flash foto, the orange led will contiuos blinking, and after a while "replace batterie", happens wih new batterie (alkaline) and NIMH 2700 fully charged batterie
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Aug 01, 2009 | Canon PowerShot A540 Digital Camera
Rechargable batteries drain as soon as they are put in the camera
Your circuit board has developed a short. There is only one way to fix it, replace the main circuit board. Buy an A530 camera with a cracked LCD online from someone, to fix it.
Nov 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
CANON POWERSHOT A530 LOW BATTERY READING
Alicia,
Mentioned on my blog that the last paragraph of the advisory states:
""PowerShot A530 and A540 digital cameras affected by this phenomenon will be repaired free of charge, regardless of warranty status. Accordingly, if the opening/closing spring on the inside of the battery cover of your PowerShot A530 or A540 digital camera sticks out, please do not use the camera. Instead, please contact a Canon call center (1-800-OK-CANON) at your earliest convenience."
But also mentioned that if they don't help, a temporary fix is to insulate the spring from the battery contact plate. Merely place a small piece of tape between the portion of spring that's sticking out and the metal battery contact plate.
Sep 09, 2008 | Canon PowerShot A530 Digital Camera
A530 flash problem
in this model the flash IC becomes faulty if so u should consult an expert.
Sep 08, 2017 | Canon PowerShot A530 Digital Camera
Canon Powershot A540 - Change Batteries when Batteries Fully Charged
May 27, 2008 | Canon PowerShot A540 Digital Camera
Camera Powershot A530 won't flash
EZ Fix for non working flash on Canon A530:
Remove batteries
Remove memory card
Remove date/time battery (tiny door next to battery hole)
Wait a minute.
Replace the items
Rest the date/time
Shoot!
Dec 12, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot A530 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
