Question about Acer TravelMate 4011 (LXTAG06011BUN) PC Notebook
The pc starts and then the fan goes off no display
Computer turns on won't boot fan runs fast
Are you getting any video display before the amber light goes off?
Aug 16, 2014 | HP Compaq Presario SR1830NX PC Desktop
When booting up blower goes wild!
Check the fan for damages, and replace it that should help with your problem.
Sep 27, 2012 | Dell Lot Of 10 Nmb-mat T2607 Cpu Blower...
Dell opitiplex 280 is not giving display. first of all his fan speed to much high and then after 4 or 5 day its display disappeared. its just picking now power and fan also start with high noise and...
OK, I use GX280s as home servers and ran into a similar problem with one of them...
The problem may be serious and not worth fixing (motherboard).
Turn power on
Fan(s) come on full power, sounds like a jet engine, or eventually gets that loud.
See if you power light has gone amber.
You get nothing on the screen, no Dell splash screen/post, nothing.
This is what I posted a while back concerning the above. Obviously I cannot bee 100% certain as I do not have your box in front of me. This a known issue.
See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans go full blast . Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad. Bottom line this is usually a defective motherboard. Mine was a bad caps issue, you issue could be different, but it does sound like the motherboard.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one link.
http://community.spiceworks.com/topic/111476-gx280-solid-amber-light-and-loud-fan
I just replaced one of my old 280s with a dual core Dell Precision 390 workstation for about $118, and that included shipping, off of ebay.
Sep 25, 2011 | Dell OptiPlex GX280 PC Desktop
My lenovo T410 displays the words "fan error" when
It's better if you call lenovo customer care and ask them to get it repaired.
Jan 14, 2011 | IBM Lenovo ThinkPad T410 2518QCU Notebook...
I have a sony vaio vgn nr430e laptop the display goes off as soon as the cpu fan starts rotating
That could be a problem with the heatsink/fan assembly on the processor. It sounds like the processor is starting up, getting warm as they do, the fan starts up but does not cool efficiently enough and forces a shut down due to heat.
Clean out the fan assembly and replace the old heatsink compound on the processor heat sink.
Hope that helps.
Dec 09, 2010 | Sony VAIO VGN-NR430E/S NoteBook
Compaq 615 froze with no display and fan whirring.
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test reports pass then perform installation of OS
else hard drive has gone bad
Apr 16, 2010 | Compaq Computers & Internet
Pc powers on but no display(light on board and fan is working)
Could be a loose Display Card... pretty rare that would happen if the System has been working fine. An event would have to occur to knock it out.
The PC should boot to the BIOS with everything unplugged in the System. Try to re-seat the Display Card first if not, unplug the Hard Drive to see if that is causing the issue. If you have an On-Board Video... pull the Display Card to see if you get a Boot.
Pull Modem as well...
If it were Memory you would get a beep. Wouldn't hurt to clean and re-seat Mem as well while your in there. Dust does cause errors because of poor connections. :)
Jan 07, 2010 | Shuttle (sn41g2b (black)) PC Desktop
Laptop will not start
It's possible the video card is burnt out from over heating.If it is you need a new motherboard.
Jun 01, 2009 | HP Compaq Presario F730US Notebook
Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
May 21, 2009 | Dell Inspiron 9400 Notebook
Averatec 6100 laptop problem
Display Driver is troublesome.
Contact Service Point and they'll reinstall the Display Driver for you.
Sahaja Yoga is the Only Solution to all the Problems of World and is the Mahaa Yoga.
Apr 03, 2008 | Averatec 6100 Notebook
Acer TravelMate 4011 (LXTAG06011BUN) PC Notebook Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
