Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a husqvarna 61 chainsaw. It has no spark from the coil. Before i replace the coil could it be another problem that is causing this.
    Sergeant:
    Champion:
  • 239 Answers
Use sand paper and clean the metal part on the coil also the aluminum wheel
Posted on Jan 01, 2009
How do I test the magneto coil?
There not much you can test. for. It either works or not. Disconnect the kill wire and try starting checking for spark. If spark is present then coil is working a further generating voltage. Check flywheel magnets to see if they good and strong.
Now ignition can fail to operate under compression so a spark gap test set at .166" need to be used. If works at this gap then it should under compression unless the high voltage is broken internally. A resistance test can tell if this is the case. Open circuit reading will most likely be broken wire. Most coil have non-replaceable leads.
Apr 18, 2015 | Husqvarna Garden
Husqvarna 61ff spark plugs problems
The early 61 has a coil on the right side, and an electronic pack at the left side of the flywheel, if there is no spark it is nearly always the electronic pack playing up, make sure the wire to the coil from the box is a good conection under the small screw, the later 61 has a single peice electronic unit, so this will need to be replaced.
Nov 13, 2012 | Husqvarna Garden
Husqvarna 266se wont start
The 266 has a two peice ignition system, the electronic pack at the lefh hand side of the flywheel is nearly always the one that goes bad, the air gap should be set at 0.3mm, the coil on the right hand side is never usually at fault.
Oct 16, 2012 | Husqvarna Models 61-66, 266, 268, 272
Husqvarna 359 - No Spark
remove the side cover and then the small wire to the coil check for spark again if still no spark the coil is bad if you get spark back the problem is the switch or wiring
Oct 04, 2012 | Husqvarna Garden
Can you recommend a replacement 14in. bar & chain that will fit a Husqvarna 61 chainsaw
There is a genuine Husqvarna 15" bar available for the 61, part no 508913156, chain part no 501841456
Jul 15, 2012 | Husqvarna Garden
I have a Husqvarna 61, it starts fine and will cut wood happily for the first five minutes of use, but then it looses power and stalls. It will start again fine, but then cuts out again soon after....
Start withe the inexpensive stuff first, pull the fuel hose out of the tank and change the filter on the end, by your discription it could also be an electrical issue, the early 61 had a two peice system, an electronic block to the left of the flywheel, and a coil at the right, if you have this system check the where the yellow two wires connect under the head of a self tapping screw under the coil, if the connection is ok it may well be a case of replacing the electronic box. The later 61 has a single peice ignition system, this may be breaking down when it gets hot, and need replacing.
Let me know how it goes, and if you need help with part numbers etc.
Mar 14, 2011 | Husqvarna Garden
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My Husquvarna Model 61 coils are not working I need a new coil where will i get an old chainsaw for spare parts for my machine now? I am in Sydney, Australia
check and search on E Bay mate, search for "Chainsawa' and "husquvarna", you should be able to pick up something cheap, also the coil from other Husquvarna models may fit, example, a 36 model coil, may fit a 61. A new coil is available from any mower and chainsaw shop, cost about $80.
May 31, 2010 | Husqvarna Chain Saw 20" Bar
I require an ignition pick up coil to suit a model 61 Husqvarna chainsaw. Availability and cost?
The IPL for a Husqvarna Chainsaw model 61 made on or before Feb 1980 lists pn-501 61 72-01 Here:
http://www.jackssmallengines.com/husqvarna_index.cfm?gclid=CNet4LC23JwCFRkpawod4iL-IQ
$64.84 plus shipping, they appaer to have at least 1 in stock.
HTH
Lou
I spent time and effort researching this for you. Please invest a little of your time and rate my solution.
Sep 06, 2009 | Husqvarna Garden
No spark
Remove cover & unplug shutoff wir from coil and replace cover & check for spark,if you have spark repair shorted wire or switch.If no spark remove coil and have checked.
Mar 14, 2009 | Husqvarna Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
299 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
