Question about E-Machines Computers & Internet
Making new paragraphs
I am a novice at the keyboard and didn't get an instruction manual in the box with my new emachines computer. I don't know if I accidentally hit the wrong key or what, but I can't start new paragraphs. When I try to start a new paragraph the words just jump up to the top line as soon as I hit the spacer bar after each word. Is there something I can do to restore it to the way it's supposed to operate or am I doing something wrong? Thank you
    Sergeant:
  • 183 Answers
Reboot mechine once.
does it do for all programs or only for specific ones?
sounds your Superscript option is enabled so post back if it does for only some specific programs so i can post back solution.
thanks
Posted on Jan 02, 2009
Factory restore
If your particular eMachines model didn't come with recovery media or you just misplaced the disc, you don't want to be caught without a means to restore the operating system.
It's all too easy to accidentally download a virus or experience any number of problems that make your computer unstable.
However, there is an option for restoring your computer without the original recovery disc by using the pre-installed recovery software.
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer.
Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner.
Do not disconnect the keyboard, mouse or monitor.
Click the Windows "Start" menu and choose "All Programs."
Navigate to "eMachines" and choose "eMachines Recovery Management." Click the "Restore" tab.
Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and click "OK." Click "Restore System to Factory Default."
Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
Select "Finish" and wait for the eMachines computer to restart.
Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your internet settings.
hope this helps
Sep 21, 2012 | eMachines T2862 Desktop PC 2.66 GHz...
How do i restore the emachine
Remove any DVDs or CDs from the optical drives and then unplug all peripheral devices except for the keyboard and mouse.
Click the "Windows" button and then type "eMachines recovery management" into the search box. Click on "eMachines recovery management" in the results list and then click the "Restore" tab.
Click "Password Settings" and then type a new password into the text box.
Click "OK" and then click "Restore System to Factory Default".
Type the recovery password into the "Password" text box and then click "OK". Click "Next" To start the recovery process.
Click "Finish" and then wait for your computer to restart.
This procedure could take several minutes. Once your computer has restarted, you'll be prompted to create a new user account, enter the date and time and set up the internet settings.
or if you are running XP
If you set your machine back to eMachines factory settings, it might help you for a short while but if you don't have effective virus protection your problems will return in short order.
You should get rid of this virus with an effective virus remover.
You can run Bitdefender's free online scan which doesn't need to be downloaded http://www.bitdefender.com/scan8/ie.html
If you know when you got the virus, you can do a system restore to a time before the virus was on your system. This article tells you how to run it from safe mode http://bertk.mvps.org/html/safemode.html
Your best protection in general is a complete internet security suite such as Bitdefender or Norton internet security 2009.
More information here http://www.ask-the-computer-doc.com/comp...
If you need to totally rebuild your system and you don't have a recovery disk, contact eMachines to get one.
You might also try a Windows repair install if you have the operating system disk. Follow the directions here for XP http://www.michaelstevenstech.com/XPrepa...
Source(s):
hope this helps
Sep 16, 2012 | E-Machines eMachines Desktop PC
Reset my desktop backc to the original settings
Source(s):
hope this helps
Aug 01, 2012 | E-Machines eMachines Desktop PC
How do i reset my emachine t5048 to factory setting without the windows boot disc?
Some computers will have a recovery partition you can recover from it will prompt you as the computer is booting. Emachines are very low end computers and don't typically have a recovery partition. If you didn't create the recovery disc you will need to order it from Gateway's website as they own emachine.You can order recovery media from https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
Oct 17, 2011 | eMachines T5048 PC Desktop
Certain keys don't respond when I use the shift key, while others do. These are the ones that are broken; 1234asdf7890jkl; I tried unplugging the keyboard and turning off the computer, then...
Replace the keyboard. Something is wrong with the encoder chip inside, and new keyboards are so inexpensive there is no point trying to repair one when it goes bad.
Jul 18, 2011 | HP CPQ175KB Keyboard
Dell set me a new keyboard to replace the original one because the keys are sticking and one fell off. No instructions and I don't how to lift up the plastic around the keyboard to replace it
Hi ktaydus.
Welcome to FixYa! How are you doing?
You did not specify the model of your dell computer.
You can check the manual online so that you know the step by step instruction on how to replace the keyboard of your dell computer.
You can go to this link: http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&cs=19&l=en&s=dhs&~ck=anavml
Just select the model of your dell computer or enter the service tag which you can find on the bottom of your laptop.
Hope that helps. Thank you for using FixYa.
Jul 18, 2011 | Computers & Internet
My keyboard will not work? I try to type and nothing happens everything else is working fine
I would recommend making sure the keyboard is connected to the proper connection on the pc. If it is, check to make sure you have no POST error when the pc reboots. (Most times your pc will halt if no keyboard is detected.) If you get no error after the reboot and your connections are correct, you will need to get a new keyboard.
PS - Make sure you 9 pins in the connector of the keyboard connection. (Look at the end that plugs into the pc you can see the pins form a semi-circle.
Good Luck
C2Solutions
Feb 19, 2011 | E-Machines eMachines Desktop PC
Kkeyboard tyypiing doublle lettters when I TYPE< AND GOES TO CAPITALS WITHOUT HITTING THE KEEY< NUMBERS DON"T WORK GET !@##$$%<< ccan"t get it to wworrk< punctuation kkeeys don"t workk...
the keyboard must be damaged for having that problems or this could happen also because a bad configurataion also u can try cleaning the keybord in a very soft way this could also be the problem
Jan 26, 2010 | E-Machines eMachines Desktop PC
T5254
eMachine's customer service was very good last I had occasion to use it. The keyboard that came with a system had a QWRRTY keyboard (E was missing) and I had the new one by 2nd day air with no return needed.
I recommend giving them a shot first since this issue may even be known to them.
I found Cnet's closing paragraph on your machine helpful too:
"We also like, as always, the BigFix application, which provides you with direct support help from Gateway, eMachines' parent company (which is, in turn, owned by Acer).
For the rest of this system's support, eMachines offers one year of parts and labor coverage, as well as 24-7 toll-free phone support. Online you get system-specific support resources, as well, along the lines of driver downloads, live chat, and other features. Because each eMachines is a fixed configuration, any support tech you come across should know exactly what kind of hardware you have, at least out of the box."
Apr 30, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
75 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
